KZ700L & KZ750L fuel tank
- Claude.
12 Mar 2021 06:55 - 12 Mar 2021 06:56
1983-84 KZ700L & KZ750L fuel tank are of the "squarish" format.
Anyone knows if such a 700/750 fuel tank does fit on KZ1000R, KZ1100R, 1983 KZ1000J3 or 1981/1982 GPZ1100? (assuming the GPZ 1100 is converted to carburetors).
Thanks!
Thanks!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 KZ1000J2 (a second one!)
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 12 Mar 2021 06:56 by Claude..
Re: KZ700L & KZ750L fuel tank
13 Mar 2021 05:49
You can compare their method of attachment. Partzilla diagrams or EB pics. If significantly different, then probably not.
13 Mar 2021 06:45
You might want to look up Daftrusty and message him. He put a later 1000 rectangular tank on his 750E. He's got crazy wide knowledge so there is a fair chance he can tell you what would have to be modded.
- 750 R1
13 Mar 2021 13:56
I'm pretty sure the front mounts fit straight up, its at the rear there could be a difference, the 750/1100 tanks look the same but there are differences, I think the 750 tank is a bit shorter with slightly less volume... Measure before you buy...
