Frame vs engine ID
  • Mr. E
  • Mr. E's Avatar Topic Author
Frame vs engine ID
26 Feb 2021 18:26 - 26 Feb 2021 18:27
#844162
Hey guys, I picked up a project today and I'm thinking I may have picked up something special.
1977 kz1000
Frame number KZT00A000265
Engine number KZT00AE000262
What could the reason be for the engine and frame numbers to not match?
How low is considered a low vin ?
1977 kz1000 - the Rooster, 1981 KZ750 Chopper, 1975 KZ400 , 1984 GPZ750
Last edit: 26 Feb 2021 18:27 by Mr. E.
  • krazee1
  • krazee1's Avatar
Re: Frame vs engine ID
26 Feb 2021 18:38
#844163
The frame and engine numbers rarely match, they are usually close. The frame number of your project is very early in Japanese production of the 77 KZ1000, probably the first week, pretty cool! If it was manufactured in Lincoln the VIN would start with a 5.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
The following user(s) said Thank You: DOHC, Mr. E
  • 73z1
  • 73z1's Avatar
27 Feb 2021 05:38
#844177
They never match
#265
The following user(s) said Thank You: Mr. E
  • krazee1
  • krazee1's Avatar
27 Feb 2021 08:25
#844193
73z1 wrote: >>>>>>>>>>>>>>>>>>>>>>>>What could the reason be for the engine and frame numbers to not match?
They never match
anc
#265
From what I've read, some of the 1st Z1s (first 20?) were assembled with the engine and frame numbers intentionally matched. I believe these were for the press release in Japan, so a rare circumstance. Other than that they are randomly assembled, but randomly does not mean a match could "never" happen. (rarely)
Mike
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
  • hardrockminer
  • hardrockminer's Avatar
27 Feb 2021 09:01 - 27 Feb 2021 09:05
#844197
Press bikes actually had 9000 series serial numbers with engine and frame identical numbers. They were pre-production. The first 100 production bikes had matching numbers. They went to major dealers. After that, a matching number would be a coincidence. I've seen one or two like that. Just guessing but the First Z1A and the last one might have matching numbers. Same for Z1B's. But I've never seen the first Z1A or Z1B.
Last edit: 27 Feb 2021 09:05 by hardrockminer.
The following user(s) said Thank You: Mr. E, krazee1
  • ronnieV
  • ronnieV's Avatar
28 Feb 2021 06:42
#844231
That's an early bike that should be stamped made in japan,like previously stated,if the vin starts with a 5 it was made in USA
  • ronnieV
  • ronnieV's Avatar
28 Feb 2021 06:49
#844234
And the first one being vin#101 that makes your bike very early .
