- Thank you received: 8
Fork oil capacity with Progressive springs. 1977 KZ650-B1
- Kozman011
01 Feb 2021 10:41 #842793
by Kozman011
Fork oil capacity with Progressive springs. 1977 KZ650-B1 was created by Kozman011
Hello everyone. Yep, sure have the manual and stock fork oil amounts. I'm putting my forks back together and wanted to know if the fork oil capacity changes at all if you are replacing stock springs with Progressive springs?
Thanks for any help you can send my way!
- Thank you received: 2070
01 Feb 2021 11:54 #842797
by Scirocco
Replied by Scirocco on topic Fork oil capacity with Progressive springs. 1977 KZ650-B1
The fork oil amount should be the same. Exeption: the manufacturer of the progressive springs made a regulation about the oil amount and viscosity.
The following user(s) said Thank You: Kozman011
