KZ1100 tank on KZ750
  • Polish
  • Polish's Avatar Topic Author
01 Feb 2021 04:22
#842771
No eBay APP ID and/or Cert ID defined in Kunena configurationHey guys,
Anybody know if a 1983 KZ1100 LTD tank would fit on a 1982 KZ750 LTD frame. Looks like it has the same fit, just not as round and a bit bigger.
Thx
JL
1979 Honda CB400T Cafe Racer (current ride)
1982 KZ750 LTD (current project)
  • martin_csr
  • martin_csr's Avatar
Re: KZ1100 tank on KZ750
01 Feb 2021 07:21 - 01 Feb 2021 07:21
#842779
It won't be a direct swap as the method of attachment at the rear is different >> the 750H uses a bolt & hardware, while the 1100 Ltd Shaft has a tab & rubber damper. Otherwise, I have no idea.
Last edit: 01 Feb 2021 07:21 by martin_csr.
  • Polish
01 Feb 2021 07:34
#842780
martin_csr wrote: It won't be a direct swap as the method of attachment at the rear is different >> the 750H uses a bolt & hardware, while the 1100 Ltd Shaft has a tab & rubber damper. Otherwise, I have no idea.
That I know. It is fine and an easy fix. I just wonder about the front where the tank fits on the frame and rubber mounts.
JL
