1979 kz1000 LTD (chain drive) chain, brake pads ??
- kz1000kz650
16 Oct 2020 04:06
Hello-
I have a 1979 kz1000 LTD chain drive. I believe it's the stock chain, but what chain do you guys use? I do see the conversion ...how costly is it and is it really worth it?
Also- doing front brakes/caliper rebuilding.....I see there are $24 ones and $40 ones.......which ones would be good?or better to get?
Thanks for any help!!
2016 CTX700(Honda)
1990 cr500(restored 100%)
1990 cr250(restored 100%)
1979 KZ650 C3
1979 KZ1000 ST(shaft)
1979 KZ1000B LTD
1979 KZ650 C3
1979 KZ1000B LTD
Re: 1979 kz1000 LTD (chain drive) chain, brake pads ??
16 Oct 2020 04:42
For brake caliper rebuilding I strongly advise you get OEM Kawasaki parts. Check Partzilla or your favorite source. If the caliper pistons are pitted they should be replaced, as should the brake lines.
For a chain converting to 530 is highly advised too. Z1 Enterprises is a good source.
The following user(s) said Thank You: kz1000kz650
16 Oct 2020 04:57 - 16 Oct 2020 05:00
Stock chain is 630 with O rings. That's what I use, mainly because they last forever. But if one ever wore out I would look carefully at converting to 530. Also, when intalling a new chain it's preferable to install new sprockets.
Lastly, if you install 630 chain and sprockets you should buy the front sprocket with a shoulder on the transmission side. This was added in 1975 to accommodate the wider O ring chain.
Last edit: 16 Oct 2020 05:00 by hardrockminer.
- racerx311
16 Oct 2020 10:03
I highly recommend the 530 chain/sprocket conversion. My '80 KZ1000 LTD , shifts better, accelerates better than with the original 630 chain/sprocket set up. I used Sunstar 530 sprockets and chain..
