Maintenance Free Drive Chain
  • Rick H.
  • Rick H.'s Avatar Topic Author
30 Sep 2020 11:52
#835922
So BMW recently announced that they have developed a maintenance free drive chain for some select models. Apparently from what I read there will be no routine adjustment necessary with this chain either. BMW is also going to release this maintenance free chain in "kit" form with sprockets for certain older models as an upgrade of around $500.00. Does anyone have any thoughts regarding this new chain? I think it is quite interesting, but as of now they don't have it in the 630 size. I think 525 is the largest they show right now. Is this a "hit" or a "miss"? The one picture I saw of the chain has the name REGINA on it I think.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Maintenance Free Drive Chain
30 Sep 2020 13:02
#835926
Sounds to good to be true , but I hope it is true
Friction and torque loads make it hard to believe
30 Sep 2020 13:11 - 30 Sep 2020 14:25
#835927
I took a look online and found a number of references to the chain. However, I did not see anything that stated a guarantee regarding how many miles or years the chain would last without any stretch or other problems. In theory, if it really doesn't stretch and requires zero maintenance I would expect BMW to provide a very long term guarantee. The internet links stated that the chain needs no lubrication maintenance and that it does not stretch, so maybe I simply missed the guarantee. Ed
Last edit: 30 Sep 2020 14:25 by 650ed.
  • zed1015
  • zed1015's Avatar
30 Sep 2020 14:32
#835932
There's a few articles on line about the chain and it's made by REGINA not BMW but the development of the friction reducing materials and coatings was probably funded by them.
Maintenance "free" diamond chains are not new, they are common in automated manufacturing and last around five times as long but are mostly in constant free running applications and not really the variable load ,speed and environment of a motorcycle drive chain.
The BMW/REGINA chain is obviously an offshoot/improvement of the diamond chain to cope with the harsher running conditions but i'd say maintenance free doesn't mean it won't wear out but that it just doesn't need any additional lubrication to what it already self supplies.
  • Nessism
  • Nessism's Avatar
  • Away
  • Rick H.
01 Oct 2020 13:33
#835985
They didn't say anything about long term durability or how long it will last. My guess is at least three years as that's the basic warranty on the BMW's that will be equipped with this chain. Regardless it should be interesting.
Rick H.
Rick H.
01 Oct 2020 14:00
#835988
Maybe I've been lucky, but I installed my Tsubaki Sigma o-ring drive chain 18 years (26,000+ miles) ago and it has only stretched about 1/4 inch. I use Maxima Chain Wax on it about every 300 miles or so. At the rate it's going I suspect it will last at least 100,000 miles which means it will outlast me. The original endless loop chain and sprockets that came on the bike when it was new only lasted 36,000 miles, but the left chain adjuster was on the right side and the right chain adjuster was on the left side and this led to premature wear of the chain and sprockets. Also, on that chain I used PJ1 Chain Lube which I don't believe works as well as Maxima Chain Wax.
I suspect the BMW chain is excellent, but I would expect it to come with a lifetime warranty if it really doesn't wear at all. The other question is what about wear on the sprockets? If the chain doesn't wear does that imply that the sprockets remain like new too? Ed
  • cb900f
  • cb900f's Avatar
01 Oct 2020 15:50
#835994
I think they call it a 'Drive Shaft'. :)
  • Rick H.
01 Oct 2020 16:30
#836000
Quite a few of the BMW's come with chains especially the high end sport bikes like the S1000 RR, S1000XR and several of their smaller bikes.
Rick H.
Rick H.
