Tires for Kawasaki KZ200 Odyssey
- msanch08
- Mike
25 Aug 2020 06:05 - 25 Aug 2020 06:12
After too long, my KZ200 tires finally failed inspection 3 weeks ago.
They were Cheng Shin, bought in about 2004 or so. I only ride a few hundred miles a year on this bike, and, store it in garage the rest of the time. So, they only showed micro cracks this year. I know they harden with time, but, the KZ is usually a 35mph bike and no cornering.
So, I have searched high and low for these sizes:
F: 2.75-18
R: 3.25-17
I finally found the rear, in stock, at Cedar Rapids Tire, in something called a Duro H319 tire. Unfortunately, they did not have the front.
Eventually, I found the front in an MMG tire on Amazon. Links to both tires are embedded in the image of the tread.
The front tread looks more like a rear tread but I will take it. My old Cheng Shin front had sort of straight line groves plus horizontal breaks, more like an old timey front tire.
I guess I am glad I am 60 now, because, when I next need tires I suspect there will be none. But, I might not need em.
Anyway, the tires are shown here.
F: 2.75-18
R: 3.25-17
1978 Kawasaki KZ200
Last edit: 25 Aug 2020 06:12 by msanch08.
- msanch08
- Mike
Re: Tires for Kawasaki KZ200 Odyssey
25 Aug 2020 06:07
Sorry,
here is a link to the image. I thought I had the process down, but, maybe not.
photos.app.goo.gl/MSdU9nhmkgfkxCxPA
1978 Kawasaki KZ200
- msanch08
- Mike
- msanch08
- Mike
25 Aug 2020 06:10
Also,
correction, the front tire is 2.75-18. Wow. I have to do better on the getting the first post correct.
1978 Kawasaki KZ200
25 Aug 2020 06:16 - 25 Aug 2020 06:24
This looks looks like a much better option. Well known company with a good reputation.
www.avontyres.com/en-us/tyres/streetrunn...0200&engine_spec=200
Last edit: 25 Aug 2020 06:24 by TexasKZ.
- ckahleer
25 Aug 2020 08:52
Are you looking for a vintage look tire?
There are tire size charts on-line that will convert your tire sizes to metric format.
1997 ZL600
94 KE100
82 KZ305
74 TC185
94 KE100
82 KZ305
74 TC185
The following user(s) said Thank You: msanch08
- msanch08
- Mike
25 Aug 2020 09:51
ckahleer,
thanks for the information on possible conversion to metric. I will do.
1978 Kawasaki KZ200
- msanch08
- Mike
25 Aug 2020 09:54
Texas KZ,
Thank you for this link. I will take a look. Avon is a good tire.
Question: The original tire rims were used with only tube type tires.
Can those same rims be used with tubeless tires like these?
1978 Kawasaki KZ200
- loudhvx
25 Aug 2020 09:58
Yes, but you must still use a tube.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- msanch08
- Mike
25 Aug 2020 10:03
OK.
Got it.
Invaluable info thanks.
Got it.
1978 Kawasaki KZ200
25 Aug 2020 10:22
To expand on Loudhvx, the rim dictates whether a tube is needed not the tire.
- msanch08
- Mike
25 Aug 2020 13:49
Understood. Thanks.
1978 Kawasaki KZ200
