KZ650 Model Identification
  • Huntmaster
  • Huntmaster's Avatar Topic Author
22 Aug 2020 17:53
#833529
I have a Lincoln built KZ650 B3 (frame KZ650B-525130) but my title document has it as a 1999 model year rather than 1979. The DMV are prepared to correct the error on "proof" of it being a 79 B3. They talk of a "letter from Kawasaki or at least a Kawasaki dealer " being acceptable. Well good luck on having Lincoln do that for a 41 year old bike. Any
Attachment not found
one with an "authoritative" document I can use? gd4now seems to be onto things. Please no Japanese sources - their numbers are a different series to the US. No I don't live in the US so having the DMV change nomenclature is not an issue - you just need "proof".
Re: KZ650 Model Identification
22 Aug 2020 20:57
#833532
Maybe the link below might help? Ed
models.kz650.info/index.htm
The following user(s) said Thank You: Huntmaster
  • M_a_t_t
  • M_a_t_t's Avatar
22 Aug 2020 23:53
#833534
You can put the vin into kawasaki's website and it will pull up year and model. Not sure if that's official enough for them.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
  • TexasKZ
  • TexasKZ's Avatar
23 Aug 2020 06:04 - 23 Aug 2020 06:05
#833538
The back cover of the factory service manual also has that information.
Do you not have a local dealer willing to write a letter for you?
Last edit: 23 Aug 2020 06:05 by TexasKZ.
23 Aug 2020 09:26
#833545
TexasKZ wrote: The back cover of the factory service manual also has that information.
Excellent point! Ed
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
23 Aug 2020 10:08
#833547
Do not know that this will help you with the title issue but to add more to this conversation here are the numbers I could find and make sense of. I am not claiming this is 100% correct, rather it was what I could find and make sense of.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Huntmaster
23 Aug 2020 15:26
#833557
This video is why mine is black. It was red.
  • Huntmaster
23 Aug 2020 15:42
#833558
Thank you. Problem is the wording on your image excludes the US model where the frame number starts with a 5 not a 0. My genuine service manual has similar wording (now that I have flipped the book over) but has wording that is ambiguous so I am going to give it a go. You never know your luck.
  • Huntmaster
23 Aug 2020 15:50
#833559
Thanks. Now that I've flipped the manual over I see what you mean. It might work so I will give it a go. The KZ was never imported into my country, only the Japanese manufactured Z version so the Kawasaki dealer network here will only have access to info on that series. Nonetheless with the info you give I will see if I can get my tame dealer to do the letter.
  • Huntmaster
23 Aug 2020 16:05
#833560
Thank you gd4now. It is from an earlier post of yours that that I found my KZ to be a B3. The title shows it as a B2 but there is no question that it is a B3. I have no clue how it got titled as a B2 let alone a 1999 model. It should be an easy task to correct the error but I have run into one of "those" officials whose life is dedicated to screwing customers around. I met a California policeman once who came from the same school of thought.
  • the_spudster
  • the_spudster's Avatar
03 Feb 2022 07:02
#861710
Thats a useful list. I have a Lincoln built bike that was imported into the UK in 93. The frame type is B2 with the single bolt front footrests and the triangular master cylinder but the frame number is 524775 putting it into the B3 category according to your list and engine numberĀ 102944 the same. Just wondering what your source for the B3 engine & frame numbers are? I guess that maybe some of the B3's could have been made with B2 frames if they were Lincoln built?
