Engine crash bars
  • Ninja
  • Ninja's Avatar Topic Author
Engine crash bars
19 Aug 2020 02:23
#833185
Hi all picked up a s/h pair of crash bars for engine cases, the guy say's they are for 77-79 but top mounting is OK, fits to engine mount, bottom mount has a triangle plate with a with 3 holes, but doesn't match with anything on frame, am I a bracket missing or different frame?
  • Rick H.
  • Rick H.'s Avatar
Re: Engine crash bars
19 Aug 2020 06:00
#833193
Pictures would no doubt help out on this.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • martin_csr
  • martin_csr's Avatar
19 Aug 2020 07:28 - 19 Aug 2020 07:31
#833197
No eBay APP ID and/or Cert ID defined in Kunena configurationThe triangular ends may need U-bolts that clamp around the frame..
Guessing the 2-pt case savers in the link below are what you got or similar.
Last edit: 19 Aug 2020 07:31 by martin_csr.
The following user(s) said Thank You: Ninja
