KZ750 swingarm on KZ500
  • Josuka98
  • Josuka98's Avatar Topic Author
  • Dutchie living in Denmark
13 Aug 2020 07:30
#832773
Hello everyone!
Hope you're all having a nice week. Currently i am working on a KZ500 hoping to turn it into a Cafe Racer. The wheels are a bit to skinny for my taste which is why I want to fit a larger rear wheel. In terms of better handling + clearance issues the only possibility I see here is a swingarm swap. I've been researching alot about cross compabilities with the KZ500 swingarm but to no avail I have found nothing.
I have been digging around for swingarms and because I am in Denmark, I have found a pretty cheap KZ750 swingarm and I was wondering if I would be able to fit it without too much machining work? Any other suggestions for a different swingarm would be welcomed!
Regards,
Asuka
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
Re: KZ750 swingarm on KZ500
13 Aug 2020 11:50
#832799
I cant tell you info on the swap, but you can compare fastener/bearing sizes on Kawasaki parts diagrams from different models and make your own assessment from that. I can tell you 900cc and larger bikes have larger axles, hardware and bearings (generally). You'll get burned trying to fit things like 900 wheels to a 650 swingarm, etc.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
The following user(s) said Thank You: Josuka98
  • Josuka98
13 Aug 2020 14:40
#832814
I’ll definitely keep note on that! Thanks a lot for your response. B) B)
  • Josuka98
14 Aug 2020 00:10
#832847
Hey guys!
For those still interested to know if it’s still doable, I’ve found this.
www.maxmcparts.eu/products/112-swingarm-...00j-en500-z500-z750/
I’m just going to bite the bullet on this one and just try to do it.
Will keep everyone updated!
  • loudhvx
  • loudhvx's Avatar
14 Aug 2020 07:32
#832873
Some years of 550 used 4 bearings and some used 2. You might want to check before you order. (We didn't get the 500 in the U.S.)
