Rear shockers
  • Ninja
  • Ninja's Avatar Topic Author
Rear shockers
10 Aug 2020 07:47
#832553
Hi guys where can I get some new top bushes for my Girling gas rear shocks 78 Z 650
  • Mikaw
  • Mikaw's Avatar
Re: Rear shockers
10 Aug 2020 09:06 - 10 Aug 2020 09:07
#832557
Without searching the parts breakdown they should be similar to my 900 And 1000 shocks. I know the tapered cone shaped two piece replacement are available thru Partzilla. If you want hourglass ones with steel bushings inside, you can size up your shock eye ID and the mounting post OD and find them at evilbay. I just went through this for my ‘78 Ltd 1000.
Last edit: 10 Aug 2020 09:07 by Mikaw.
The following user(s) said Thank You: Mr. E, Ninja
