'79' shafty with a lot of vibration
- Greg Davis
23 Jul 2020 12:13
Hi All, I'm new here but am a member of Kz1300.com. I recently purchased an "79' 1000st to have a rider while working on the 1300'
My question is the 1000 seems to have an unusual amount of vibration, reminding me of my old h1 500 it is strong enough to numb my hands
after a 30 min. ride. What could be causing this? any help would be appreciated. Thanks Greg
Re: '79' shafty with a lot of vibration
23 Jul 2020 16:14
Twisted crank?
The following user(s) said Thank You: Greg Davis
- Greg Davis
24 Jul 2020 10:50
Assuming it is a twisted crank how would one go about checking for this? Require a tear down or can be done with indicator from the ends of crank or measure
pistons 1-4 at top dead center {just guessing on that one) I have a full machine shop, so not afraid of attempting much but would rather not tear it down
unless needed.
unless needed.
- krazee1
24 Jul 2020 13:26
Verifying that cylinders 1&4 are at TDC at the same time, and then the same check for 2&3 would eliminate a twisted crank as the cause of your vibration. Could be accomplished with a TDC finder or dial indicator through the spark plug hole along with a pointer or degree wheel. Unless your bike was subjected to full throttle starts with a sticky tire, a twisted crank on a 79 model would be unusual/unlucky. I think the twisted crank thing became more prevalent in the early 80s with the J motors. I did have a buddy that twisted the crank on a 1982 CSR1000, the result of drag racing. Have you checked to be sure your motor mounts are tight?
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
- ghostdive
24 Jul 2020 16:01
More details would help narrow it down; my 750 shaft was vibrating a TON before I balanced my carbs. It also may be that your timing is off!
Does it vibrate at a particular speed or RPM range?
2001 ZX-6R
2001 ZX-6R
24 Jul 2020 16:51
I was thinking the same thing as ghost dive.
