Sprocket change for differnt size chain
  • DenimJeanes
  • DenimJeanes's Avatar Topic Author
21 Jul 2020 13:22
#831151
I got a free KX550 frame off Craigslist a month or so back. the original plan was to fix it up, until i realized how how messed up the carbs engine and frame were. Thr frame is still usable for a project just not good for a street bike. Ive Got a Honda Clone, small engine, 196cc and a torque converter that requires 420/#35 chain. i want to throw this engine on the frame and remove all the junk i dont need. my one problem so far is finding a sprocket compatible with the rear wheel of the KZ550. Any links or or idea would be welcomed. Thanks!
  • TexasKZ
  • TexasKZ's Avatar
Re: Sprocket change for differnt size chain
22 Jul 2020 06:26 - 22 Jul 2020 06:26
#831193
So what you need is a sprocket that will fit the GX200 and a 530 chain? I bet that will have to be custom made. You might try JT Sprockets. Tell them what you want and see if they have a solution.
www.jtsprockets.com
Last edit: 22 Jul 2020 06:26 by TexasKZ.
  • Mikaw
  • Mikaw's Avatar
22 Jul 2020 07:45
#831199
Personally I thought your Mel Tillis impersonation was pretty good.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
22 Jul 2020 09:31
#831208
TexasKZ wrote: So what you need is a sprocket that will fit the GX200 and a 530 chain? I bet that will have to be custom made. You might try JT Sprockets. Tell them what you want and see if they have a solution.
www.jtsprockets.com
FIXED your stutter
  • TexasKZ
  • TexasKZ's Avatar
22 Jul 2020 11:19
#831219
Thththththanks, Dddddddave!
  • :laugh:
  • 1982 KZ1000 LTD parts donor
    The following user(s) said Thank You: Street Fighter LTD, Mikaw
    • Mikaw
    • Mikaw's Avatar
    23 Jul 2020 06:01
    #831257
    TexasKZ wrote: Thththththanks, Dddddddave!
  • :laugh:
  • Now that’s funny, I don’t care who you are!
