short throttle cable
- gixxerkidd03
09 Jul 2020 16:22
i looking for a short throttle cable that i can run with clip-ons for my kz750. i have one thats really close but maxed out with too much free play, it has a 91 cm inner cable and 81cm out side. i will need something just a little short. any info will help.! thanks!
1981 KZ750e
- F64
- 81-KZ440D2
Re: short throttle cable
09 Jul 2020 19:36
81-KZ440-D2.
LIC, NY
LIC, NY
10 Jul 2020 06:30 - 10 Jul 2020 07:26
Motion Pro makes custom cables & probably other places. maybe Barnett.
91 cm seems kind of short already, but maybe look into a GPz or a smaller motorcycle.
Z1Enterprises lists the stock 750E cable as 39.75" (101 cm), but I didn't see one for a 550 GPz or 750 GPz & didn't look for
any others. At Z1Ent if you search by model, cables are listed in the maintenance section.
Last edit: 10 Jul 2020 07:26 by martin_csr.
10 Jul 2020 08:33
I'm using an OEM GPz cable on my 750E, along with superbike bend bars which are quite a bit lower than stock. Wish I wrote down the PN of the cable I found because it's shorter than stock but has the proper end fittings to work with both the hand control and carbs (even though the GPz's used Mikuni carbs and the E's used Keihin carbs.) My clutch cable is a GPz part too. Motion Pro does make a lot of different cables but can't say I'm impressed with the quality. I'll take OEM over MP any day.
