Can I run with no air in forks?
- hawken
02 Jul 2020 20:19
I have an 83 KZ 750 with air assist forks. It has an air balancer that runs between the forks, so I can’t reposition the forks to lower the front or to install clip-ons without releasing the air. Is it safe to ride with no air?
I’m looking at eventually installing progressive springs.
Re: Can I run with no air in forks?
03 Jul 2020 05:53
FWIW. My air forks don't have a balancer, and it's so difficult to check & air up the forks properly that I don't bother any more. I did clean & rebuild the forks w new seals & dust boots and added fresh fork oil as per the manual (1981 KZ650-CSR).
I've seen some old topics in which is was recommended to install new quality progressive springs & just eschew the air.
03 Jul 2020 06:13 - 03 Jul 2020 06:15
If you leave the hole open in the fork tube you may loose oil and there will be no pressure build up in the forks during compression which is a natural spring assist reducing bottoming tendency.
Also, without the air the forks will feel quite soft. Replacing the springs with some new straight rate springs from Sonic was a significant upgrade on my bike. As for straight rate vs progressive, this is a good read... sonicsprings.com/catalog/straight_vs_prog_tech_article.php
Last edit: 03 Jul 2020 06:15 by Nessism.
03 Jul 2020 07:35 - 03 Jul 2020 12:51
If he doesn't install the balancer or plug the holes, he will loose oil. probably quite a bit.
Last edit: 03 Jul 2020 12:51 by martin_csr.
- hawken
03 Jul 2020 08:23
What do you recommend for plugging the holes? I’ve seen a few threads where that was mentioned, but no one has mentioned how to do it.
