Brake Pad Replacement - KZ750
  • TexasKZ
  • TexasKZ's Avatar
Re: Brake Pad Replacement - KZ750
29 Jun 2020 14:53 - 29 Jun 2020 15:00
#829362
Looks like Denis Kirk sez the whole bloody thing is about 9.5mm thick, so the friction material should be 6 or 7 mm.
www.denniskirk.com/ebc/brake-pads-fa68.p195071.prd/195071.sku
According to the fitment chart there,this pad fits most of the 700/750 range - models A, H, L K, R, N and a bunch of 1000 and 1100 models.
Last edit: 29 Jun 2020 15:00 by TexasKZ.
29 Jun 2020 15:20
#829373
If I'm reading this correctly you are trying to replace the front brake pads on a 1983 KZ750-N1 Spectre. Assuming that is correct, I suggest you simply buy the correct Kawasaki brake pads which according to the Kawasaki site (see link below) are part number 43082-1021. They are available on eBay, just search using Kawasaki 43082-1021 as the search criteria. If they do not fit there must be a different problem to be solved. Ed
www.kawasaki.com/Parts/PartsDiagram/145779/1983/KZ1100-D2
  • Mikaw
  • Mikaw's Avatar
29 Jun 2020 15:45
#829383
650ed... you and I come up with different part number's for the same bike...
www.partzilla.com/catalog/kawasaki/motor...kz750-n1/front-brake
29 Jun 2020 17:16
#829390
Mikaw wrote: 650ed... you and I come up with different part number's for the same bike...
Interesting. I wonder if both or either one is correct. Ed
  • TexasKZ
  • TexasKZ's Avatar
29 Jun 2020 17:23
#829391
I wonder if one is a superseded number?
