Front brake line length kz650
  • martin_csr
  • martin_csr's Avatar
Re: Front brake line length kz650
24 Jun 2020 09:18
#828852
It's difficult to say for certain what forks they are, but your motorcycle has leading axle forks which were used on various Ltd & CSR models. I'd guess they're from a 750-Ltd, but that is just a guess. Also, the forks are raised in the triple tree, so that will affect what brake line lengths to get. I wouldn't order anything until you can get to the motorcycle so you can figure out what the correct length should be.
  • q-base
  • q-base's Avatar Topic Author
24 Jun 2020 09:58
#828862
martin_csr wrote: It's difficult to say for certain what forks they are, but your motorcycle has leading axle forks which were used on various Ltd & CSR models. I'd guess they're from a 750-Ltd, but that is just a guess. Also, the forks are raised in the triple tree, so that will affect what brake line lengths to get. I wouldn't order anything until you can get to the motorcycle so you can figure out what the correct length should be.
Thanks a lot. Okay it seems like I need to do the 200km round trip to avoid having to return too many brake lines.
1977 kz750
Instagram: @jmreiche
  • martin_csr
24 Jun 2020 11:18 - 24 Jun 2020 13:36
#828877
You could do as Nessism suggested & fabricate your own brake lines. See his reply on previous page. He has a write-up w pics somewhere here on KZR. probably in his restoration topic. Then do the Fr brake when convenient.
Last edit: 24 Jun 2020 13:36 by martin_csr.
  • q-base
24 Jun 2020 22:21
#828932
Ahh yes, I did not even see that. But I think I run the risk of having problems with MOT here in Denmark, if I fabricate my own, unfortunately.
1977 kz750
