1984 GPZ550 rear brake stuck
  • dpivas7
  • Topic Author
18 Jun 2020 11:58 #828392 by dpivas7
1984 GPZ550 rear brake stuck was created by dpivas7
The rear brake on this 1984 GPz550 I am working on is stuck. when you press on the brake lever, the lever doesn't return, even though the spring is still attached to the mechanism. The reservoir is filled with fluid to the correct level.
Does it need a simple brake bleed or is there something wrong with the caliper?
Current: '19 Harley Roadster, '72 XLCH, '84 GPz 550
Past: '84 GPz 550, '82 KZ750 LTD, '71 XLCH
  • Scirocco
  • Premium Member
  • Premium Member
18 Jun 2020 12:36 #828398 by Scirocco
Replied by Scirocco on topic 1984 GPZ550 rear brake stuck
Looks more like an rear MC and caliper clean and rebuild Job.
  • TexasKZ
18 Jun 2020 13:27 #828402 by TexasKZ
Replied by TexasKZ on topic 1984 GPZ550 rear brake stuck
Could be the brake lever pivot. It is one of those oft neglected maintenance items. Water and dirt can build up, causing rust on the pivot shaft.
  • dpivas7
  • Topic Author
18 Jun 2020 13:41 #828404 by dpivas7
Replied by dpivas7 on topic 1984 GPZ550 rear brake stuck
The brake stays locked, even if I pull the lever up
  • TexasKZ
18 Jun 2020 14:09 - 18 Jun 2020 14:11 #828406 by TexasKZ
Then it seems a full hydraulic rebuild is in order, though I would still pull the lever off to clean and grease the pivot. Be sure to carefully clean the seal groves in the caliper.
Last edit: 18 Jun 2020 14:11 by TexasKZ.
The following user(s) said Thank You: dpivas7
  • dpivas7
  • Topic Author
18 Jun 2020 14:43 #828411 by dpivas7
Ahh okay! Would it be sufficient to buy a caliper rebuild kit?
  • ThatGPzGuy
18 Jun 2020 15:48 #828416 by ThatGPzGuy
Replied by ThatGPzGuy on topic 1984 GPZ550 rear brake stuck
This just happened to me on my XS650. You'll need to pull the MC and rebuild it. I would suggest honing as well since the piston is probably seized in the bore.. Try that first and then, if needed, rebuild the caliper.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Nessism
18 Jun 2020 16:01 #828417 by Nessism
Replied by Nessism on topic 1984 GPZ550 rear brake stuck
Motorcycle master cylinders should not be honed. Pull it apart and inspect for pitting in the aluminum. If it's okay install an OEM piston kit and replace the brake line. Same goes for the caliper, only instead of worrying about the bore look at the pistons.
19 Jun 2020 12:52 #828476 by ned37
Replied by ned37 on topic 1984 GPZ550 rear brake stuck
sounds like the small return bleed hole in the mc is plugged, keeping the pressurized fluid from returning from the caliper
'83 GPZ1100, '97 Triumph Trophy 1200, '08 Husky TE610
Verde Valley, AZ
  • dpivas7
  • Topic Author
28 Jun 2020 12:11 #829216 by dpivas7
I don't see a bleed hole anywhere.
  • dpivas7
  • Topic Author
28 Jun 2020 14:32 #829226 by dpivas7
Nessism wrote: Motorcycle master cylinders should not be honed. Pull it apart and inspect for pitting in the aluminum. If it's okay install an OEM piston kit and replace the brake line. Same goes for the caliper, only instead of worrying about the bore look at the pistons.
I can't find any rebuild kits for a 1984 GPz550. Would a 1982-1983 rebuild kit work? The manual says "The rear master cylinder on ZX550-A1 and A2 models has changed slightly from other models" so I don't know if a 1983 would work.
Also can't find any complete rear master cylinders for less than $300
  • Mikaw
28 Jun 2020 15:18 #829242 by Mikaw
Replied by Mikaw on topic 1984 GPZ550 rear brake stuck
This is the tiny hole that allows pressure to be released and allows the caliper to back off a smidge and not drag
