Kz650b1- 750b1 front wheel install
- Anybody51
26 May 2020 16:38
undefined I need some help installing the front wheel, instructions, I should have a manual but don't because the only piece of the b1 is the front forks, thanks in advance,
Jimbo
Jimbo
Re: Kz650b1- 750b1 front wheel install
28 May 2020 07:11 - 28 May 2020 07:17
Here is an exploded view showing the orientation of the various parts. Other than that, it should be like most other front wheel installations.
www.partzilla.com/catalog/kawasaki/motor...6/kz750-b1/front-hub
I believe this manual covers the 750 B1, so you can find the torque specifications and other details of front wheel installation.
www.kzrider.com/modules/ServiceManuals/K...l%20KZ750%20Twin.pdf
Last edit: 28 May 2020 07:17 by TexasKZ.
- H1Vindicator
28 May 2020 08:08 - 28 May 2020 08:26
should be exactly the same. the hub part numbers and axle are the same. check the numbers yourself.
Last edit: 28 May 2020 08:26 by H1Vindicator.
28 May 2020 09:35Anybody51 wrote: undefined I need some help installing the front wheel, instructions, I should have a manual but don't because the only piece of the b1 is the front forks, thanks in advance,
Jimbo
I may be confused regarding your bike, but if you need any info on the 1977 KZ650-B1 see www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
31 May 2020 06:28650ed wrote:Anybody51 wrote: undefined I need some help installing the front wheel, instructions, I should have a manual but don't because the only piece of the b1 is the front forks, thanks in advance,
Jimbo
I initially thought he was putting a 750 wheel on a 650 motorcycle, but in rereading the post, I am now thinking he has a 750 motorcycle and wheel, with 650 forks. Dunno. Either way, I hope he got it together.
