'80 KZ440-A1 Chain Replacement Types
  • spoon
  • spoon's Avatar Topic Author
16 May 2020 15:17
#825880
Hey all,
I'd like to replace my chain on '80 KZ440-A1, I know the size is 530 x 104 Links, but I was curious if anybody has any experience with an O or X-ring chain on this bike? I was set to go with a Niche X-Ring chain, but then I saw that some older bikes might have a problem with the clearances needed for the wider o/x-ring chains.
Thanks for any imput!
-Eric
'80 KZ440A LTD - Stock (for now...)
  • Nessism
  • Nessism's Avatar
Re: '80 KZ440-A1 Chain Replacement Types
16 May 2020 19:44
#825891
I wouldn't worry about chain width; the x-ring chain will only be minimally wider than a regular chain. That Niche chain strikes me as a little suspect though. A 440 most likely won't over stress it though.
  • Nebr_Rex
  • Nebr_Rex's Avatar
17 May 2020 16:42
#825966
An X or Oring chain is overkill on a 440.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • Nessism
  • Nessism's Avatar
17 May 2020 16:46
#825968
Nebr_Rex wrote: An X or Oring chain is overkill on a 440.
No no no! Quality is never overkill. Sprocket life is better because the chain elongates less. And all you need is a small spray of chain wax every now and then with a good chain, with a cheap chain you need to spray it regularly with a real lube which is messy as heck.
