81 Gpz 550 seat modification
  • Ant_5445
  • Ant_5445's Avatar Topic Author
16 May 2020 05:11
#825836
Hi everyone, got a couple questions. I'm trying to modify my 81 gpz550 seat to look like an ELR seat. I'm just wondering what would be the best way to go about this? I'm thinking of using the original seat foam, cutting and shaping it, and getting a replacement cover. However, i haven't seen to many replacement seat foams for this bike so if i were to ever go back i wouldn't be able to. I have been seeing a lot of seats for 82-83 550s around on ebay...are these the same foams used in the 81 or completely different? They look like the same length and width so maybe i could buy one cheap , cut into that instead while using the 81 pan, and use a replacement cover? Any other suggestions? Thanks!!
'99 Zrx 1100
'81 Gpz 550
  • mjg15
  • mjg15's Avatar
Re: 81 Gpz 550 seat modification
10 Jun 2020 20:30
#827831
I see this thread is a couple months old, but if you haven't done it yet, 82-83 are different. I haven't see any replacement foam for a 550. The 80-83 A model 550 a similar foam, but not the same. It's a little thinner (in height), and not quite the same quality, but may work perfectly for what you want to do. If you're in the USA, and still need something to work with, I may have a foam that will work for you
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • Ant_5445
11 Jun 2020 04:12
#827844
Thanks for the reply. I just ended up cutting into the original foam and put a new cover on it. Works perfect and its actually comfortable..not as bad as i thought it would be.
'99 Zrx 1100
'81 Gpz 550
  • TexasKZ
  • TexasKZ's Avatar
11 Jun 2020 06:11
#827850
Picture?
  • Ant_5445
11 Jun 2020 07:00
#827859
1st pic was before.
2nd pic was cutting the foam and mocking it up on the bike. All i did was follow the first indentation up to the higher part of the back of the seat. I took 2 inches off.
3rd pic is when it was finished.
Bought a new seat cover while i was at it at Z1. However, the cover was pre fit to the original foam so it didn't conform right. Had to take that to an upholstery shop as i didn't feel comfortable taking the stitches out and end up ruining the seat cover. Makes a hell of a difference when riding alone and even 2 up...not sliding everywhere.
'99 Zrx 1100
'81 Gpz 550
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
11 Jun 2020 07:26
#827864
That made a great looking bike look even better. Well done.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
The following user(s) said Thank You: Ant_5445
  • loudhvx
  • loudhvx's Avatar
11 Jun 2020 10:53
#827895
Excellent job on the seat!
