82 GPZ 1100 bolt size for seat rail and helmet locks.
  • DNort
  • DNort's Avatar Topic Author
13 Apr 2020 23:47
#823295
Hello! New to the forum, New to the GPZ 1100, but not new to forums, motorcycles, or fixing most things myself.
Would anyone happen to know the bolt size and thread pattern for the bolts that go through the helmet locks that hold the seat rail in place? While I still own the seat rail, the former owner took it off and I'd like to re attach it. Knowing the size and threading of the bolts would save me a lot of fumbling around during a quarantine.
I am also looking for a "passenger" side helmet lock. Is this something I can purchase new anywhere? would anyone be willing to sell me one?
Attached is a picture of my bike currently without the seat rail, and an older picture from the previous owner where the seat rail is still attached.
Thank you in advance for any help!
82 kawasaki GPZ 1100
Mostly stock with 82 gs1000 swingarm
  • martin_csr
  • martin_csr's Avatar
Re: 82 GPZ 1100 bolt size for seat rail and helmet locks.
14 Apr 2020 07:21 - 14 Apr 2020 07:32
#823320
The bolt sizes are usually listed in the parts diagrams, but not the pitch. Partzilla is the easiest site to use & has a cross-reference.
You might be able to find a new or NOS helmet lock on EB. Find the part number at Partzilla in the diagrams for your motorcycle, then search EB & be sure to check the "include description" box when searching part #s. If that doesn't work, then try KZ1100 helmet lock or whatever other models use the same part. and try other search terms. GPz 1100. etc.
Last edit: 14 Apr 2020 07:32 by martin_csr.
The following user(s) said Thank You: DNort
14 Apr 2020 07:36
#823322
Take a look at www.kawasaki.com/Parts/PartsDiagram/143852/1982/KZ1100-B2 to see the part number of the bolt. If it is Part Number 115C0870 the folks at www.megazip.net/zapchasti-dlya/kawasaki/...-8x70-black-115C0870 claim to have it. If they don't actually have it, or if that is not the correct part, using the part number in your internet search may help you find it. Ed
  • martin_csr
14 Apr 2020 08:34 - 14 Apr 2020 08:50
#823328
8x70mm is a long bolt. Whatever size he needs, a good hardware store should have something.
Last edit: 14 Apr 2020 08:50 by martin_csr.
  • DNort
14 Apr 2020 22:18
#823401
Thank yoy for all the help everyone! Having an idea of the thread pitch really helps me out as everything is really weird right now with the quarantine.
  • Mikaw
  • Mikaw's Avatar
14 Apr 2020 22:23
#823402
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
15 Apr 2020 02:47
#823410
Buy the bolt and match it up to a 8mm tap. Theres usually just the standard metric pitch and a rarely used fine thread.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
