1979 master cylinder flat ring part number
- ez_goin112
13 Apr 2020 20:28
Hello all. I'm rebuilding and painting my 1979 kz1000 front master cylinder. It is currently fully disassembled for prime and paint. The parts diagram does NOT show that the removal of 2 screws inside the plastic reservoir will allow you to remove it from the aluminum housing. Under the plastic is a well that feeds the line.
I need a part number for the EPDM flat ring under the reservoir. The original is not broke just too flat i suspect. If I'm this far in i feel i would rather just replace it. Any help would be much appreciated.
- gd4now
- Denco where did you go?
Re: 1979 master cylinder flat ring part number
13 Apr 2020 21:21
I do not know the part # but this link has them.
www.redlinecycle.com/Brk%20-%20Trap%20Rsrvr%20O-%20Ring.html
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: ez_goin112, Mikaw
13 Apr 2020 21:45 - 13 Apr 2020 21:46
I had bought one from him years ago but couldn’t find the actual page and didn’t want to post something I couldn’t be 100% sure of. Thanks for finding that.
Here is a link to a replacement of that O-Ring.
www.kz-1000.net/post/3676028622/kz1000-master-cylinder-rebuild
Last edit: 13 Apr 2020 21:46 by Mikaw.
