KZ750N1 - Rear Brake Pedal - Help getting it on
  • dnpurdy
  • dnpurdy's Avatar Topic Author
13 Apr 2020 04:59
#823209
Hey all,
I am looking at getting my rear brake pedal back onto the splined shaft, and it isn't wanting to go on really at all. I suspect if I'm able to open up the gap normally closed by the clamping bolt, I'd have a much easier time.
Any recommendations for how to safely and easily open that up to allow the pedal to go on easier?
(1980 KZ440-A1 sold project bike)
(1982 KZ750-N1 still stolen)
1982 KZ750-N1, my only now
  • Rick H.
  • Rick H.'s Avatar
Re: KZ750N1 - Rear Brake Pedal - Help getting it on
13 Apr 2020 06:31
#823213
Maybe I am too simplistic, but all I have ever done to accomplish opening up the gap on a brake pedal or shifter lever is inserted a flat bladed screwdriver into the slot and twisted the screwdriver to force the gap open. Works for me.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • dnpurdy
13 Apr 2020 06:44
#823216
I have tried that, but unfortunately I lack a bench vice or something to hold it while I do it, so I can't quite get enough leverage to open it up. :(
Was hoping people had fun, crazy methods :)
  • martin_csr
  • martin_csr's Avatar
13 Apr 2020 07:01 - 13 Apr 2020 07:02
#823220
Maybe you could use a C-clamp instead of a bench vise. clamp it to a work table with a block of wood to protect the brake pedal.
Last edit: 13 Apr 2020 07:02 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
13 Apr 2020 07:13
#823223
Can you wedge a screwdriver in, and leave it there while you slip the lever on?
  • dnpurdy
13 Apr 2020 07:57
#823228
Helpful suggestions!
C-clamp and reversing the clamping bolt against a metal flat for the win, pushing the opening open :)
  • martin_csr
13 Apr 2020 11:27
#823251
Very clever way to do it, threading a bolt into the brake pedal to push it open.
  • Rick H.
  • Rick H.'s Avatar
14 Apr 2020 07:06
#823317
dnpurdy wrote: I have tried that, but unfortunately I lack a bench vice or something to hold it while I do it, so I can't quite get enough leverage to open it up. :(
Your final solution was pretty ingenious, but how do you survive without a bench vise? I use mine all the time for different stuff and I can't imagine not having one.
Rick H.
Rick H.
  • martin_csr
14 Apr 2020 08:53
#823331
I don't have a bench vise either, but I do have a selection of various woodworking clamps & C-clamps. a bench vise would be handy, though. :)
  • Rick H.
  • Rick H.'s Avatar
14 Apr 2020 15:09
#823372
I am shocked! I use my vises for all sorts of things and have 3 of them. A big and little one in the basement and a big one in the garage. I couldn't imagine not having at least one. I am not knocking anyone for not having a vise, but it's my third hand a lot of times. The two big ones have interchangeable jaws for different purposes like holding round or flat objects. I just don't know how you make do without one.
Rick H.
Rick H.
  • martin_csr
14 Apr 2020 17:37
#823387
If I really needed a bench vise, I probably would have gotten one already, so I guess I don't really need it.
