lubricating the innertube
- SpecialGreen
10 Apr 2020 12:16 - 10 Apr 2020 12:16
I'm mounting new tires with new tubes today. I've read that I should use baby powder between tube and tire to allow the tube to slide around into a good position without creasing. And to air it up, let the air out, and air it up a second time.
I've read that baby powder is now mostly cornstarch due to asbestos concerns, and not so good in tires anymore. Anything else to use? I have baking soda, blue chalk (from chalk string line), some graphite powder... I also wonder why I shouldn't just paint the inside of the tire with soapy water (I mix Dawn + water 50/50 and use that to lubricate the bead while mounting). I could make a run to the store, but am trying to avoid meeting too many people this month (coronavirus).
Last edit: 10 Apr 2020 12:16 by SpecialGreen.
- Kidkawie
- I bleed premix
Re: lubricating the innertube
10 Apr 2020 13:03 - 10 Apr 2020 13:04
Baby powder. You wont die and it wont hurt your tubes.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 10 Apr 2020 13:04 by Kidkawie.
- bluej58
10 Apr 2020 13:23 - 10 Apr 2020 13:24
If you have spoke tires I would not use soapy water, it promotes inside rust IMO
Baby powder is what I use too, do it out side because if you get some on the floor it's very slippery
78 KZ1000 A2A
Last edit: 10 Apr 2020 13:24 by bluej58.
10 Apr 2020 13:47
For the past 55 years I've always mounted my own motorcycle tires and always used baby powder on the tubes. So far, so good.
10 Apr 2020 15:59
Baby powder on tubes improving fitment is an urban legend. As commonly discussed on bicycle forums as oil threads are on motor vehicle forums. Don't waste your time.
- z1kzonly
10 Apr 2020 16:55
Speaking of inner tubes! I need a wider 18" for a small 5.5" slick on a 3.5 aluminum rim. Having a hard time finding one. Most are small 3.50/4.00. Or 120/130. Wonder how small I can go. Looking at the Harleys, they have 18" wide on some models but most are tubless on aluminum rims? Wonder if I can seal this spoke rim??? with a 1/2" of silicone bead?
- Nebr_Rex
10 Apr 2020 18:06
I was into stockcar racing back in the late nineties.
Mounted my own tires with tubes, baby powder makes a hell of a difference.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Kidkawie
- I bleed premix
10 Apr 2020 19:17 - 10 Apr 2020 19:18z1kzonly wrote: Speaking of inner tubes! I need a wider 18" for a small 5.5" slick on a 3.5 aluminum rim. Having a hard time finding one. Most are small 3.50/4.00. Or 120/130. Wonder how small I can go. Looking at the Harleys, they have 18" wide on some models but most are tubless on aluminum rims? Wonder if I can seal this spoke rim??? with a 1/2" of silicone bead?
Check out Jake the Garden Snake XR650 supermoto build on youtube if you want to convert spoke to tubeless.
1975 Z1 900
2004 KX125
2004 KX125
Last edit: 10 Apr 2020 19:18 by Kidkawie.
10 Apr 2020 20:50 - 10 Apr 2020 20:53
I noticed that the rims Jake the Garden Snake used had the extra ridge that would help keep a tire in place if air was lost or the tire was bumped sideways. Unfortunately many tube type KZ rims don't have that ridge, so there's a risk that the tire without a tube could lose all pressure under certain circumstances. Ed
Last edit: 10 Apr 2020 20:53 by 650ed.
- M_a_t_t
11 Apr 2020 04:52SpecialGreen wrote: I'm mounting new tires with new tubes today. I've read that I should use baby powder between tube and tire to allow the tube to slide around into a good position without creasing. And to air it up, let the air out, and air it up a second time.
I think he is looking for an alternative.
I think you kind of answered your own question. Since it is arguably noncritical lubrication I would just use cornstarch or other similar powder.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
- kevski
11 Apr 2020 06:31 - 11 Apr 2020 06:32
Use ground up chalk, will behave like talc, which is like having millions of microscopic ball bearings, allowing the surfaces to roll over each other, FDA still doing research into this matter, been using talcum since I were a baby, 58 years and ain't dead yet.
Last edit: 11 Apr 2020 06:32 by kevski.
11 Apr 2020 07:33
I would think using organic matter would act as glue or at least make a mess. Always used baby powder and always will.
