KZ1000P1 center stand
  • Mack
  • Mack's Avatar Topic Author
25 Mar 2020 19:33
#821773
My KZ1000P1 is very difficult to put on centre stand Does any one else have this problem? If so are there any solutions I’m thinking it is probably caused by the after market rear shocks I installed they are about a inch shorter than the stock ones were
Re: KZ1000P1 center stand
25 Mar 2020 19:54
#821774
It generally comes down to technique. Maybe the video below will help. Ed
  • M_a_t_t
  • M_a_t_t's Avatar
25 Mar 2020 21:06 - 25 Mar 2020 21:08
#821777
I struggle with my 1100 even using the technique above. I have to put the rear wheel on a couple layers of card board (minimum) to get it up.
Shorter shocks don't help because you've effectively increased the distance you have to get the weight of the bike off the ground.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
Last edit: 25 Mar 2020 21:08 by M_a_t_t.
  • david richard
  • david richard's Avatar
25 Mar 2020 23:29
#821778
hi mack im in the uk and i have a z1r ,from standard they have a very short bit for you to place your foot on and for to push about 2 inchs in length ,it does not matter how strong you are its just awkward could it be the same ,david
  • 78kawltd
  • 78kawltd's Avatar
  • 1978 B2, 06 Heritage Softail,
26 Mar 2020 03:23
#821785
Hello Mack. I recently installed a center stand and encountered the same issue. I had discovered the solution is to roll the bike's rear wheel onto a wood board. Approx. 1.5 inches. thick x 12 inches. It makes the task easier for one person. The helpful tip was discovered while searching this forum by the way. Perform a quick kzrider forum search to reveal the image included with the tip.
Charlie
  • 78kawltd
  • 78kawltd's Avatar
26 Mar 2020 03:37
#821786
Search center stand. And. User was. Patton
www.kzrider.com/forum/5-chassis/610791-g...-center-stand#805182
  • kevski
  • kevski's Avatar
26 Mar 2020 03:54
#821788
Technique is really key here, i come in at only 150 pounds these days and find it easy to put my bikes on the main stands, but yous has absolutely been made harder by lowering the bike by about an inch, this in effect puts the part of the stand that rolls on the floor at completely the wrong angle meaning the downward force needed to roll has to be hugely increased, i am sure you will develop the technique to overcome this though.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
26 Mar 2020 07:13
#821803
Probably doesn't help but my KZP is the worst one to get up on and especially off the center stand and that is bone stock. My other Kawasaki's are much easier.
The easiest bike I ever owned to put on a center stand was my mid 80's Honda Interceptor.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
27 Mar 2020 06:47
#821888
ThatGPzGuy wrote: Probably doesn't help but my KZP is the worst one to get up on and especially off the center stand and that is bone stock. My other Kawasaki's are much easier.
Our '93 CB 750 Nighthawks are the same way; Honda really got the geometry right. Don't even have to dismount.
- While straddling bike keeping it upright, push down on centerstand tang with left foot. Rock left/right slightly & feel for both pads to contact floor.
- While keeping both centerstand pads on the floor, simultaneously stand on tang with full,body weight and tug back on the handlebars. Bike just pops up onto the centerstand.
Our '09 ST1300A is the opposite, if not using a thick shim under the rear tire. A notoriously difficult, heavy lift up & to the rear. Full body weight on the tang while lifting with the fold out handle. The Lovely Z1BEBE always helps with the lift too, using the grabrail.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • M_a_t_t
  • M_a_t_t's Avatar
27 Mar 2020 12:31
#821920
kevski wrote: Technique is really key here, i come in at only 150 pounds these days and find it easy to put my bikes on the main stands, but yous has absolutely been made harder by lowering the bike by about an inch, this in effect puts the part of the stand that rolls on the floor at completely the wrong angle meaning the downward force needed to roll has to be hugely increased, i am sure you will develop the technique to overcome this though.
+1 I weigh even less and can (barely) put my 1100 on the center stand. But that's mostly because of my shoes. They are thin and pushing down on the center stand foot pad starts to hurt my foot and some days I'm just not up for that.
Little story:
When I first got my bike (1100 was my first bike) my uncle showed me how to put it up on the center stand by throwing his body weight towards the rear. He is a big guy probably 250+. I tried that and there was no chance. After watching the video 650ed posted I was able to get my bike on the center stand.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
  • ob1jeeper
  • ob1jeeper's Avatar
14 Apr 2020 21:29 - 14 Apr 2020 21:29
#823398
My "vertically challenged" neighbor was having similar issues with a new Guzzi Dual Sport he recently purchased. After some careful measurements, (using shims of wood, under BOTH tires, until we achieved an effort level that was good for him), I removed and shortened (cut the legs, then re-welded) both the center stand and the kick stand for him. Now he is easily able to get in on the center stand, and the lean angle is much improved so a gust of wind won't topple it... ;)
Last edit: 14 Apr 2020 21:29 by ob1jeeper.
