KZ550 swingarm and wheel assembly?
  • sumowilkie
  • sumowilkie's Avatar Topic Author
21 Mar 2020 02:56 - 21 Mar 2020 02:59
#821280
Hi Guys, Im in need of your expert advice.
Story so far, on doing a complete rebuild of a kz550 with new frame install Bike had been hit while stationary and front of frame was bent.
iv come to fit the wheel on the original existing swingarm.
I cant get the spacers in as i see from the various diagrams, and seems to be 10mm to tight.
I dont remember it being a problem to remove, but theres been a few beers since then.
Before i assume that the swing arm is damaged wondered if someone could tell me if theres any diference between the kz550 models before i buy another.
Can someone measure the distance between the hub point on the swingarm, inside measurment please.
Pictures of the spacers and small gap 4-5mm and spacer still to go in.
This is assuming i have the right order and someone can show me the errors of my ways, im no expert and this is my first bike rebuild.
Thanks martin
Last edit: 21 Mar 2020 02:59 by sumowilkie.
  • martin_csr
  • martin_csr's Avatar
Re: KZ550 swingarm and wheel assembly?
21 Mar 2020 05:28 - 21 Mar 2020 05:51
#821285
Howdy. In the 1st pic I'm not sure what the thing is around the axle. Is that a misplaced collar/spacer? see pic below.
If it's any help, my 81 KZ650-CSR rear wheel stuff is virtually the same as yours & I have a KZ550 Ltd wheel mounted >> there's a gap of about 11mm between the swing arm adjuster & oil seal. Also, the center-to-center spacing of the swing arm adjuster bolts is 9-13/16" or thereabouts. Both measurements are kind of crude but pretty close. Assuming it's a 550C Ltd, I think yours probably should be the same.
Last edit: 21 Mar 2020 05:51 by martin_csr.
The following user(s) said Thank You: sumowilkie
