how to raise the rear of the bike so the chassis angle is lower in the front.
  • onion
  • onion's Avatar Topic Author
19 Feb 2020 11:11
#819581
I have kz1000j3 with new suspension front and back and 18" wheels.
  • baldy110
  • baldy110's Avatar
Re: how to raise the rear of the bike so the chassis angle is lower in the front.
19 Feb 2020 14:36
#819588
Well good for you!
The following user(s) said Thank You: 650ed, martin_csr, SWest
  • riturbo
  • riturbo's Avatar
19 Feb 2020 14:40
#819589
PICS PICS PICS We need pics . Welcome . We cant help without them.
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • TexasKZ
  • TexasKZ's Avatar
20 Feb 2020 04:21
#819601
Basically, there are two ways. Use shocks that att adjustable for length, or use longer shocks.
You can get the same effect by raising the fork tubes in the triple clamps.
Either way, you need to be very careful. The farther from the stock setup you get, the more you increase the tendency for the bike to go into violent tank slappers.
Why do you want to do this?
  • martin_csr
  • martin_csr's Avatar
20 Feb 2020 05:40 - 20 Feb 2020 05:41
#819605
Topic title sounds like he was going to shed some wisdom, but then left out the details. :huh: :)
Last edit: 20 Feb 2020 05:41 by martin_csr.
  • Rick H.
  • Rick H.'s Avatar
20 Feb 2020 12:13
#819623
I sometimes do that but later read my own post and hit the edit function.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • TexasKZ
  • TexasKZ's Avatar
20 Feb 2020 15:11
#819628
martin_csr wrote: Topic title sounds like he was going to shed some wisdom, but then left out the details. :huh: :)
This means that no matter what anybody posts, it will be the right answer :silly: :blink: :woohoo:
  • martin_csr
20 Feb 2020 15:25 - 21 Feb 2020 05:44
#819629
That first reply is a gem. i.imgur.com/PkLryAo.gif
Last edit: 21 Feb 2020 05:44 by martin_csr.
  • onion
20 Feb 2020 16:58
#819634
I'm sorry, but no pics to look at yet . Just striped the bike to the bare frame. But to see what I mean, look at any pic of a kz1000r to see that ,they all seem to sag in the middle. Levelling the tank seat and tail section is a good start ,but angling the frame to a more modern stance is my goal.
The following user(s) said Thank You: martin_csr
  • onion
20 Feb 2020 17:04
#819635
Thanks for your help.
