Temperature brake disc
  • gordone
  • gordone's Avatar Topic Author
08 Feb 2020 15:04
#818840
Hi,
How hot can the brake disc front and rear get maximum for normal driving on road?
Air temp. here in Norway is normaly never much over 77 Fahrenheit.
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Temperature brake disc
08 Feb 2020 15:56
#818853
Norway is very restrictiv in top speed and speed controls, so no trouble with brake disk temperature.
  • gordone
08 Feb 2020 23:07 - 09 Feb 2020 00:54
#818878
Driving down the deep tunnels under the ocean I guess is where I get highest temp and down the mountains on a warm summer day.
I will use a 200 degree celcius paint, should be good to go then... I hope...
Project:
Last edit: 09 Feb 2020 00:54 by gordone.
  • martin_csr
  • martin_csr's Avatar
09 Feb 2020 07:22
#818884
I don't know how hot a brake disk gets. It seems to me you'd need a paint suitable for the highest possible expected temperature. The disk probably gets very hot applying the brake going down a mountain .
  • gordone
09 Feb 2020 14:49
#818911
Will use a 200 C. Degree paint.
Thank you
Project:
