1976 KZ900 fork disassembly
Re: 1976 KZ900 fork disassembly
29 Dec 2019 13:27
Spacer with spring seat is 41mm
Upper tube length is 615mm overall
Lower from axle cap split is 345mm
29 Dec 2019 13:33
Found this torque spec page in the kz manual. The Allen isn’t called out
The next page in the manual has generic torque per bolt size and pitch. Top paragraph states to only use this if the specific bolt is not covered in the previous page.
It’s a 10mm bolt but I don’t have thread pitch gauge. Then I used this spec for my ‘78 B2 rebuild I did this past fall...
29 Dec 2019 13:37 - 29 Dec 2019 13:43
I’m sure I’d be safe at the 14.5-19 ft lbs that Ed’s chart calls out. Basing that on the B2 spec and the general diameter/pitch chart
Last edit: 29 Dec 2019 13:43 by Mikaw.
29 Dec 2019 13:46
Sorry for the overwhelming photos. Posting them for others that might find themselves in the same dilemma.
29 Dec 2019 14:15 - 29 Dec 2019 14:16
...and don´t forget to use a new copper washer under the Allen head bolt or you have to do your work twice!!!
Last edit: 29 Dec 2019 14:16 by Scirocco.
29 Dec 2019 14:50Scirocco wrote: ...and don´t forget to use a new copper washer under the Allen head bolt or you have to do your work twice!!!
Thank you... I pulled out what looked like a fiber or plastic washer.... I used copper on my ‘78... no leak yet... is the fiber original?
29 Dec 2019 15:31
On all fork i have done a copper was used and never ever found any fiber washer.
29 Dec 2019 16:02
Scirocco, thank you!!!
Don’t want to leave out any contributors.... Thanks Everyone
29 Dec 2019 16:03
My 1977 KZ650-C1 uses copper too. Ed
29 Dec 2019 19:14
When I rebuilt my Z1 forks I found fiber. But if you order OEM as I did you will get copper.
