Headlight bracket
  • Kz81
  • Kz81's Avatar Topic Author
Headlight bracket
25 Nov 2019 11:59
#814533
I am looking for the headlight bracket and bucket for my 1981 kz1000j. I removed the vetter fairing and need the factory headlight parts. The headlight bucket/bulb are available on ebay, but I can't find the bracket that mounts them to the front forks. This is the only part I need to get the bike finished. Any help locating the bracket would be appreciated. I included a picture. The bracket for a Ltd or CSR model will not fit. I think this bracket is specific to 81-83 1000j models. Thanks!
  • davido
  • davido's Avatar
Re: Headlight bracket
26 Nov 2019 04:53
#814574
Best to try the beakers in your area. What country are you in?
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • 73z1
  • 73z1's Avatar
26 Nov 2019 05:56
#814577
You are looking for a rare part.
Check ebay every week, search kz1000 head light bracket and part number.
  • Kz81
26 Nov 2019 07:02
#814580
I'm in the US. No salvage yards in my area, but I have looked/will continue to look online. Thanks!
  • Kz81
26 Nov 2019 07:06
#814581
I agree, its definitely a rare part. I've mainly looked on ebay. Hopefully, I can travel to some of the bigger swap meets held in the US each year. Thanks!
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
26 Nov 2019 10:29 - 26 Nov 2019 10:36
#814591
No eBay APP ID and/or Cert ID defined in Kunena configurationFound a KZ 1000J headlight bracket on German ebay.
bikemaster900.de/All-parts-sorted/-Z-100...TLE-RUST::12810.html
Last edit: 26 Nov 2019 10:36 by Scirocco.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
26 Nov 2019 10:51 - 26 Nov 2019 10:57
#814593
Perhaps one from an 81-82 KZ1100 would work until you find the correct one. Plenty of those available (11036-1038)
:whistle:
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 26 Nov 2019 10:57 by daveo.
  • Kz81
26 Nov 2019 11:43
#814595
That looks very interesting. I notice the ears are in a lower position on the bracket than the one in my picture. When I look at the partsfische diagram at Kawasakioemparts, it shows the ears at the top. I'll do some further checking. Thanks!
  • Kz81
26 Nov 2019 12:25
#814599
I had considered the same thing. Thank you.
  • martin_csr
  • martin_csr's Avatar
27 Nov 2019 05:35
#814637
For the one Daveo suggested, maybe you could cut off the upper mounts & get them re-welded in the correct position. I'm assuming the fit otherwise is good, but the bottom mount doesn't look the same so that could take some fiddling. I would fab up a jig to hold the bracket & upper mounts in the correct position for welding.
