Identify my bike
- piddlinhilger
Identify my bike
18 Nov 2019 19:36
Hello there, I apologize in advance I just today picked up a KZ 650 and was wanting to know how to tell which one I have. I have the title, its a 78 but I don't know about the letters following. Where do I find this?
Re: Identify my bike
19 Nov 2019 05:54
On the headstock, the front part of the frame that the steering stem goes through, there should be a white decal with the frame number and date of manufacture. Compare your number to the ones listed on the back cover of the factory service manual. If you don't have one, get one. In the mean time, you can post the number here and one of the members who has a manual can look it up.
Keep in mind that model year does not correspond to calendar year. For instance, Kawasaki started building 1978 models in July or August of 1977. Titles can be wrong.
19 Nov 2019 05:59
This may also help. It is filed with the service manuals under the articles tab
www.kzrider.com/modules/ServiceManuals/M...nition_1963-1978.pdf
Also, you need the manual for your exact year and model since Kawasaki made several significant changes to the 650 during its lifetime.
19 Nov 2019 06:28
TexasKZ gave great advice. Also post pictures because the different 1978 KZ650 models should be pretty easy to tell apart. Ed
19 Nov 2019 10:19 - 19 Nov 2019 10:20
Last edit: 19 Nov 2019 10:20 by martin_csr.
- piddlinhilger
- piddlinhilger
20 Nov 2019 19:41
Ok guy's I got the numbers.
KZ650C-013216. Its a light blue in color.
- piddlinhilger
20 Nov 2019 19:48
Looks like its the metallic star dust silver (looks real light blue to me), but the dark blue and persimmon red are definitely not it. Now next question, how do I get my hands on these manuals?
20 Nov 2019 20:14 - 09 Dec 2019 04:25
OK. As you say, it's probably a 1978, but take a look at the images below to be sure. The 1977 has 3 allen screws as part of the generator cover, the 1978 and later models do not have the screws, and the 1979 and later models used upper/lower case lettering. Since the VIN has the "C" in it I'm sure it's a KZ650-C model.
Also-
The KZ650 B models came with wire wheels, a single front disk brake, a drum rear brake, and an 18" rear wheel.
The KZ650 C models came with cast wheels, dual front disk brakes, a disk rear brake, and an 18" rear wheel.
The KZ650 D (also called SR) models came with cast wheels and a 16" rear wheel
After you are absolutely positive about the year and model you can find the manual on eBay. There are significant differences between the various year KZ650's, especially in the charging systems, so be sure to get the Kawasaki Service Manual for your exact model. Ed
1977
1978
1979
Also-
1977
1978
1979
Last edit: 09 Dec 2019 04:25 by KZQ.
- piddlinhilger
21 Nov 2019 05:48
Lols like 78. Thank you for all the great info! I’m really enjoying learning about these bikes.
- loudhvx
22 Nov 2019 06:04 - 22 Nov 2019 06:04
The "Kawasaki " logo on the alternator cover looks like the photo for 1979 that Ed posted.
Of course, it's possible someone replaced the cover.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 22 Nov 2019 06:04 by loudhvx.
