75 kz400 fork assembly
- Cafekz400
17 Nov 2019 19:46
hey guys I bought this bike in pieces and now its time to re assemble.
got new seals already but need to know the following.
-first off am i missing any parts
-how exactly does this go back together
-what kind of oil do i use ( i weight 190lbs and live in alberta aka shitty roads don't want to be to soft )
if any one has a good video or guide or service manual thanks in advance.
Re: 75 kz400 fork assembly
18 Nov 2019 06:41 - 18 Nov 2019 06:50
Kawasaki.com & Partzilla have parts diagrams. partzilla is easier to use.
KZ400.com has a pdf factory service manual. not sure how much detail it will have on the fork reassembly.
Some of the links on the manual page don't work, but scroll down >> the bottom section has the individual scans from the manual.
Warning: from what others have reported: the forums there may harm your computer. But the tech pages seem to be okay.
Last edit: 18 Nov 2019 06:50 by martin_csr.
The following user(s) said Thank You: Cafekz400
18 Nov 2019 06:50
Take a look at the link below. Regarding fork oil - I have used Bel Ray 15w Fork Oil for many years in my KZ650 and it works great. I weigh a bit more than 200 lbs. Ed
www.kawasaki.com/Parts/PartsDiagram/142697/1975/KZ400-D
- Cafekz400
19 Nov 2019 06:05
If those are the original springs, I think it would be a good idea to replace them now. Even just the weight of the bike not moving will compress them over time. Progressive, Sonic and Race Tech are the places I would check first.
19 Nov 2019 06:10
You can also download the manual from this forum. The manuals are under the Articles tab.
www.kzrider.com/modules/ServiceManuals/7...chablefullmanual.pdf
- Kidkawie
- I bleed premix
19 Nov 2019 20:44
Google: damper rod fork assembly
Very easy.
Very easy.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
