Csr 1000 m1 1980 tyres.
  • Davey b
  • Davey b's Avatar Topic Author
30 Oct 2019 14:28
#813284
Hi, can anyone on here recommend anywhere I can get tyres and tubes for my 81 csr in the uk. Spose I could import them but would probably be too expensive!!
The old girl's been laid up for 23 years so tyres are looking a bit tired !!!
1981 kawasaki kz1000 m1 csr
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Csr 1000 m1 1980 tyres.
30 Oct 2019 15:22
#813289
It would be helpful what size of tires and tubes do you Need. Some UK members had a great source of cheap local bike parts in the UK.
The following user(s) said Thank You: Davey b
  • martin_csr
  • martin_csr's Avatar
31 Oct 2019 05:33
#813309
In the USA the KZ1000-M1 CSR would be a 1981 model. 1980 might be the date of mfg which doesn't always correspond to the model year >> same as any other vehicle.
From the Dunlop motorcycle tire cross-reference, the 1000-M1 CSR tires are 100/90-19 Fr & 130/90-16 Rr. same size as my 81 KZ650-CSR. I'm currently running Bridgestone Battlax BT45s.
  • davido
  • davido's Avatar
01 Nov 2019 02:20
#813357
Ive got BT45s on my Bandit. Theyre a good all round tyre!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • Nessism
  • Nessism's Avatar
  • Away
01 Nov 2019 05:43 - 01 Nov 2019 05:50
#813364
I've been using Pirelli Sport Demon tires on my KZ650 since 2009; I just mounted my third set. I've used Michelin and Dunlop tires in the past and other than the old Michelins with PZ2 race track compound (which totally wore out in 1,000 miles) the Pirelli tires far exceed them. I'm certain that Pirelli tires are available in GB, and they do offer 16" rear and 19" front Sport Demon tires. The video below describes the Sport Demons. Ed
Last edit: 01 Nov 2019 05:50 by 650ed.
  • Davey b
01 Nov 2019 09:31
#813380
Thanks all for your feedback, mine is indeed an 81 m1 model. On it at the moment are dunlop mm90 h 19 front and dunlop elite gt mu90 hb 16 rear, possibly been on it from new ?( only shows 11000 miles ) but I dont know if that's true.
It says on the rims "tubeless on tubed type rim" so I assume I will need tubes too ??
  • Davey b
01 Nov 2019 09:58
#813383
Might give these a try. Sounds like a really good deal.
Maxxis m6011, £125 for the pair !!
Found them on ebay , company called "mytyres"
Anyone tried these ??
01 Nov 2019 13:36
#813395
  • Nessism
  • Nessism's Avatar
  • Away
01 Nov 2019 14:09 - 01 Nov 2019 14:20
#813396
The 1981 CSR KZ1000 uses spoke wheels right? That's what the USA parts fishe shows anyway. At any rate spokes = tubes.
Last edit: 01 Nov 2019 14:20 by Nessism.
