Forks max travel distance
  • Busabenny
  • Busabenny's Avatar Topic Author
15 Oct 2019 19:45
#812533
Hello. 1980 kz440 Ltd. that has stock forks. From roughly where the outermost lower fork tubes sit, how far up the inner upper fork tubes, will the lowers travel? Basically I have rust pitting on the inner tubes about 2” up and I’m trying to see if that will be a problem. Thanks
  • martin_csr
  • martin_csr's Avatar
Re: Forks max travel distance
16 Oct 2019 05:11 - 16 Oct 2019 06:26
#812538
Probably around 6". .. The service manual should list the amount of wheel travel in mm. see the technical specs section at the beginning of the manual. The KZ400.com site has a Kawasaki 440 FSM. I looked at it last week. click the 2nd "here" where it says you can download it.
Forum warning: the forums there may harm your computer.
Last edit: 16 Oct 2019 06:26 by martin_csr.
  • Busabenny
16 Oct 2019 05:58
#812540
Ok. Then I think I have to get my fork tubes rechromed because the pitting starts at 2” thanks
  • martin_csr
16 Oct 2019 06:27 - 16 Oct 2019 06:30
#812542
You might be able to find a good set forks on EB. not sure how expensive re-chroming would be.
Last edit: 16 Oct 2019 06:30 by martin_csr.
16 Oct 2019 07:26
#812545
You may want to contact the folks at the link below. They do forks. Ed
franksforks.com/
  • Busabenny
16 Oct 2019 09:50
#812552
I asked on FB and they also mentioned franks. So I sent them an email. Worst case I’ll get them rechromed, I don’t think it will cost much.
  • Warren3200gt
  • Warren3200gt's Avatar
16 Oct 2019 09:55
#812553
If you go for a re chrome be careful. Too thick and they will have sticky travel, too thin and you will feel them knock when you use the front brake.
  • Busabenny
16 Oct 2019 10:05
#812554
Ok thanks. I’ll bring it up when I get it done if I go that way.
  • Busabenny
17 Oct 2019 09:25
#812595
Frank quoted $405. A little much for me.
17 Oct 2019 15:03
#812616
Busabenny wrote: Frank quoted $405. A little much for me.
That is a lot of money! Ed
