Brake Fluid in a modern master cylinder
  • martin_csr
  • martin_csr's Avatar Topic Author
10 Oct 2019 15:53 - 10 Oct 2019 15:53
#812203
I'm installing a modern Honda Fr brake master cylinder & new ss braided brake lines onto my 81 KZ650-CSR w stock caliper.
On the mc cap it says to use Dot 4 & I'm planning on using Dot 4. AFAIK, dot 3 & dot 4 can be mixed and dot 4 has a higher boiling point.
Other than the boiling point, is there some other reason why dot 3 shouldn't be used? Just wondering. Thanks.
Last edit: 10 Oct 2019 15:53 by martin_csr.
  • Nessism
  • Nessism's Avatar
Re: Brake Fluid in a modern master cylinder
10 Oct 2019 16:43
#812210
No reason 3 can't be used. Just as you state, 3 & 4 are compatible.
The following user(s) said Thank You: martin_csr
