Newbie kz750 Owner
  • scottybadkid
  • scottybadkid's Avatar Topic Author
  • 1983 KZ750
Newbie kz750 Owner
16 Sep 2019 11:46
#810931
Hey All,
I'm new to the forum. I just picked up a 1983 KZ750 4 cylinder that I want to turn into a brat/scrambler hybrid. I'm looking for a more square-ish fuel tank (sorry stock bike lovers! ;)
I've heard that the 1982 kz550 or gpz tanks might by swapped with a lil' modification. Any recommendations for this or other threads I should look at for my project?
Thanks for any help with this!
  • martin_csr
  • martin_csr's Avatar
Re: Newbie kz750 Owner
16 Sep 2019 13:05 - 16 Sep 2019 13:11
#810933
Howdy. The tripe tree will probably bang against & ding a larger tank. There are probably some fixes for this >> maybe have a welder add some material to the steering stop peg or drill a hole thru the peg & add a bolt or something. These things will reduce the turning radius, but would probably only affect pushing & maneuvering the motorcycle around in tight spots, such as in a garage or driveway.
Last edit: 16 Sep 2019 13:11 by martin_csr.
The following user(s) said Thank You: scottybadkid
  • Nessism
  • Nessism's Avatar
  • scottybadkid
  • 1983 KZ750
17 Sep 2019 08:09
#810967
holy crap
  • martin_csr
17 Sep 2019 09:20
#810971
What KZ750 do you have? I was assuming an Ltd without thinking. doh.
  • scottybadkid
  • 1983 KZ750
17 Sep 2019 12:52 - 17 Sep 2019 13:32
#810977
KZ750-F LTD
Anyone know if a 1981 Kawasaki KZ550D1 Fuel Tank (GPZ550) could be modified to fit on this bike?
Last edit: 17 Sep 2019 13:32 by scottybadkid.
  • scottybadkid
  • 1983 KZ750
18 Sep 2019 08:48
#811015
Anyone know of square-ish tank option that wouldn't be too tough to modify to fit this bike? Any guidance appreciated...
  • martin_csr
18 Sep 2019 11:52 - 18 Sep 2019 13:05
#811021
I don't know how easily a GPz type tanks can be made to fit. The 550 is a smaller motorcycle, so that GPz tank might be too short. A 750-GPz, KZ750-L3 or KZ700 tank might be a better fit. You could measure the distance between your front tank mounts & also measure the length of your tank from the Fr tank mounts to the rear of the tank. Also, note how deep the frame channel is >> a GPz might have a deeper channel. guessing. Then compare your numbers to a potential donor tank.
Also, the KZ750E has a larger tank than an Ltd, but it isn't squarish like a GPz fuel tank. The 750E tank is a direct bolt-on to the 750H Ltd chain drive frame, but the Ltd upper triple is kind of straight across & will bang against it; the Ltd Shaft triple tree is similar. The 750E triple tree is angled forward to allow clearance for the larger tank.
Last edit: 18 Sep 2019 13:05 by martin_csr.
  • scottybadkid
  • 1983 KZ750
18 Sep 2019 13:39
#811028
Great info- thank you.
