Front brake wont let go
  • Nessism
  • Nessism's Avatar
  • Away
Re: Front brake wont let go
05 Sep 2019 09:38
#810396
Here is a photo from when I cut open my KZ750 brake line. The red grunge is sludge that will quickly contaminate any new fluid that may be introduced into the system.
[img
P1010652 by nessism , on Flickr
  • Shdwdrgn
  • Shdwdrgn's Avatar
05 Sep 2019 11:27
#810402
@TexasKZ - I'm actually talking about my *back* brakes, your picture looks more like the master cylinder for the front?. Guess I should have started a new topic to avoid confusion -- sorry.
@TexasKZ and Nessism - it wouldn't surprise me if these are the original brake lines on the bike, however there appears to be no restriction through the lines when I'm bleeding the brakes, and I haven't seen any discoloration of the fluid (unlike the front lines which DO have that reddish color in them). Basically the brake will apply just fine with no resistance, the problem is then it won't release completely.
1981 KZ1000-JK1
She's a beautiful mess, and I've made her all mine
  • dsr9024
  • dsr9024's Avatar Topic Author
05 Sep 2019 15:59
#810413
Alright so after several suggestions from you fine people and others I have talked to in person, im going to replace my brake lines given my current issues and the bikes previous issues when i first got it. Now i want to put brand new lines on, but ebay is all used and im at a loss as to where to go, plenty of websites sell new lines for everything but the KZ440, at least that i have found, any suggestions?
  • riturbo
  • riturbo's Avatar
05 Sep 2019 16:29
#810415
Definitely wouldn't hurt to get new lines but you will still need to clean or rebuild the master . My turbo was doing that a few years back . I switched the master from a gpz 1100 and havent had a problem since .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Shdwdrgn
  • Shdwdrgn's Avatar
22 Sep 2019 21:19
#811178
I finally got a chance to tear down the rear brake today to try and figure out what was going on. I took apart what I guess serves as the master cylinder for the reap brake, the part that the pedal causes to pump the fluid. Everything looked pristine clean inside but I went ahead and hosed it out with brae cleaner. I didn't see anything that looked like a bleeder hole though. Put everything back together and once I got fluid pumped back through it seemed to lock up again. Well hmm. I decided to press down the caliper so I could at least drop in the new brake pads while trying to figure out what was up, and that's when I discovered the problem... the caliper itself was frozen.
Once I popped the caliper apart I saw a ring of sludge near the top of the piston. Tried to clean it up with a wire brush but then I noticed that there are actually gouges in the piston forming a ring about 1/4" from the top, and they look fairly old. Once I got it cleaned the piston slid back into the caliper smoothly and I was able to put everything back together again.
The brakes, with the new pads, are working perfectly at this point. My theory is that a previous owner ran the pads down to bare metal at one point, causing some chattering which created the damage ring in the piston. After I put the bike back together with new pads it was working fine until the pads wore down to the point where the damage caught against something inside the caliper, jamming the piston and preventing it from sliding. Now that I've put new pads back in again, the piston is pushed in further and not getting caught (at least until this set of pads wear down again). It will probably work fine for awhile, so next time we have a nice day I'll go for a ride and burn through the full tank of gas I have, then I can park it for the Winter.
Since I don't know what kind of damage might also be inside the caliper, I think the only plan here is to just get a whole new caliper assembly and scrap this one. At least it is easy to swap out.
1981 KZ1000-JK1
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
23 Sep 2019 00:41
#811180
All you have to do to diagnose a locking brake is crack open various fittings/bleeders until it frees up.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
