81 Ltd rear wheel compatibility
Re: 81 Ltd rear wheel compatibility
21 Jan 2020 04:20 - 21 Jan 2020 04:21Nerdy wrote:TexasKZ wrote:Nerdy wrote:TexasKZ wrote: If you are asking about an LTD 1000, then I think the rear wheel from the P series police bikes will work without too many headaches. If you are asking about one of the smaller LTDs, then I have no idea.
The small LTDs (e.g. 440) had 16" rear wheels.
So did the bigger ones, but the axle diameters, wheel width, brake rotor diameter and rotor spacing from centerline, wheel spacers and such are different.
That's okay, the 440s don't have a brake rotor on the back - drum only.
So did some larger models. Some had wire spoke wheels while most had cast aluminum. This is why we really need to know which year and model the op has.
Last edit: 21 Jan 2020 04:21 by TexasKZ.
21 Jan 2020 07:49 - 21 Jan 2020 07:50
He indicates that it's an 81 Ltd & mentioned the Z1, so surely it's a 1000-K1. you never know sometimes, though.
Last edit: 21 Jan 2020 07:50 by martin_csr.
- deano68
22 Jan 2020 13:18
the police wheel goes in easy without any issues the sprocket carrier is also interchangable. the swing arm goes in also ive not long done the same thing see z/kz mk3 in the projects section
76 KZ 400
78 KZ 650
82 Z 750(4)
80 KZ1000 ltd project
82 CSR 1000 work in progress
78 KZ 650
82 Z 750(4)
22 Jan 2020 20:26
I guess since the op has not logged on to KZR since August 8, 2019, he must have gotten all the info he wanted.
