81 Ltd rear wheel compatibility
  • Phillystyle_13
  • Phillystyle_13's Avatar Topic Author
04 Aug 2019 16:41
#808707
Looking to go to an 18” rear mag on my 81ltd. I know the z1 will work but what else will. Having trouble finding one off of a z1
  • TexasKZ
  • TexasKZ's Avatar
Re: 81 Ltd rear wheel compatibility
04 Aug 2019 17:42
#808715
If you are asking about an LTD 1000, then I think the rear wheel from the P series police bikes will work without too many headaches. If you are asking about one of the smaller LTDs, then I have no idea.
  • TexasKZ
  • TexasKZ's Avatar
04 Aug 2019 17:43
#808716
Z1 did not have mags, it had wire spoke wheels.
  • Phillystyle_13
04 Aug 2019 18:10
#808719
This is what I have. Looking for the same rear wheel in 18”
  • hardrockminer
  • hardrockminer's Avatar
04 Aug 2019 20:14 - 05 Aug 2019 13:55
#808722
Z1 mags? They are indeed very hard to find. Other than after market. But you don't want a Z1 wheel because the hub (and other parts) is totally different. No rear disc brake.
Last edit: 05 Aug 2019 13:55 by hardrockminer.
The following user(s) said Thank You: Phillystyle_13
  • TexasKZ
  • TexasKZ's Avatar
05 Aug 2019 17:52
#808781
The ELR had an 18 inch cast wheel with disc brake, but I bet they are really hard to find and quite pricey. I'd put my money on the P series cop bike wheel.
  • wera90ex
  • wera90ex's Avatar
20 Jan 2020 06:33
#817469
Just used this site to look for Kaw parts . Haven't seen a reference to it on here. www.kawasaki.com/Parts/PartsDiagram/134510/1982/KZ1000-P1
81 LTD 1000 cleaning up POV's (owner/vandals) messes
81 Yamaha 750 seca
81 Yamaha XS650
80 Suzuki GS 250 E
82 Suzuki gsxr 450 /597 race bike, single shock 750 gsxr forks
  • martin_csr
  • martin_csr's Avatar
20 Jan 2020 07:39 - 20 Jan 2020 07:40
#817472
By wera90ex: Just used this site to look for Kaw parts . Haven't seen a reference to it on here. www.kawasaki.com/Parts/PartsDiagram/134510/1982/KZ1000-P1
Partzilla & other places have the same diagrams, but Partzilla is the easiest to use & partzilla has a cross-reference.
cmsnl.com also has the diagrams, plus cmsnl has the diagrams for some Euro models not available at most places, including Kawasaki.com.
Last edit: 20 Jan 2020 07:40 by martin_csr.
  • Nerdy
  • Nerdy's Avatar
20 Jan 2020 09:46
#817480
TexasKZ wrote: If you are asking about an LTD 1000, then I think the rear wheel from the P series police bikes will work without too many headaches. If you are asking about one of the smaller LTDs, then I have no idea.
The small LTDs (e.g. 440) had 16" rear wheels.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Mikaw
  • Mikaw's Avatar
20 Jan 2020 10:03 - 20 Jan 2020 10:04
#817482
I checked Partzilla and an ‘81 LTD1000? uses the same axle as the KZP up till 2005. So a good chance an 18” KZP as Texaskz suggested would appear to swap in.... really need to know the OP’s cc.
Last edit: 20 Jan 2020 10:04 by Mikaw.
  • TexasKZ
  • TexasKZ's Avatar
20 Jan 2020 11:32 - 20 Jan 2020 11:33
#817493
So did the bigger ones, but the axle diameters, wheel width, brake rotor diameter and rotor spacing from centerline, wheel spacers and such are different. If the op has a 1000 LTD that he wants to install an 18 inch wheel on, then I think the cop bike wheel may be an easy, affordable choice. If the op has a 200 LTD that he wants to convert to 18 inch, I have no idea what might fit.
Last edit: 20 Jan 2020 11:33 by TexasKZ.
  • Nerdy
  • Nerdy's Avatar
20 Jan 2020 13:34
#817496
That's okay, the 440s don't have a brake rotor on the back - drum only. :)
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
