Kz1000p spoked wheel swap.
- KZPwheelies
12 Jul 2019 19:11 - 12 Jul 2019 19:27
I got a set of kz spoked wheels given to me today, not sure what kind of kz they came off of but the are awesome! Anyways I am looking for some information on swapping the wheels onto my 1998 KZ1000P. I want the spoked wheel because I also plan on doing a gsxr usd front end down the line and I know they make a laced hub for that front end so I can have matching spoked wheels. I know I'll lose my speedo but that's not a problem.
Last edit: 12 Jul 2019 19:27 by KZPwheelies.
Re: Kz1000p spoked wheel swap.
13 Jul 2019 06:55
How many spokes are the wheels? The 70s 1000A had 40 spokes w steel rims & 18" Rear wheel and the 1000-CSR had 48 spokes w aluminum rims & 16" Rr.
I would compare the hub components & other stuff at Partzilla, making an educated guess what the donor wheels are from.
- KZPwheelies
13 Jul 2019 07:25
After taking a closer look it appears that they are 40 spoke wheels. The rear sproket does not fit my chain so I believe it's a 530 chain. The rim is a little bit wider than my stock mag and has a 150 tire on it the contacts the brake arm when I try mount it. The front axle is also slightly smaller than the front wheel.
