Upgrade brakes kz400 1979
- Johio
10 Jul 2019 09:31
Hello,
i feel that the front disc brake of my kz400 is lacking a bit of stoppning power. I have to push pretty far on the handle but it still doesnt stop very well.
In what order should upgrades be made? Performance and cost-wise. Best bang for the buck upgrade?
Was thinking of Steel braided lines..
Kind regards Johan
Kind regards Johan
Re: Upgrade brakes kz400 1979
10 Jul 2019 10:21
First priority might be new brake pads.
10 Jul 2019 11:07
In addition to the brake pads which could be glazed, if the motorcycle still has the original rubber brake hoses, then you should replace them. ss braided lines are a common upgrade. There are all sorts of choices available, but I installed Goodridge lines & fittings from Z1Enterprises.com. CycleBrakes.com has Galfer brakes lines with integrated fittings that are crimped on.
- Nerdy
10 Jul 2019 18:25
Your master cylinder might be worn out. If the piston is not sealing well [inside the master cylinder] you will likely have poor braking coupled with longer lever travel.
And I second the motions that your pads and lines should be inspected and probably replaced.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
