81 GPZ550 fork diameter
  • Mikey_V
  • Mikey_V's Avatar Topic Author
10 Jun 2019 18:26
#805482
New to the forum and bikes in general, so apologies if this has already been answered. What is the fork diameter on the 81 GPZ550? From what I’ve found I think it’s 35mm but I wanted to confirm with the pros
  • loudhvx
  • loudhvx's Avatar
Re: 81 GPZ550 fork diameter
10 Jun 2019 21:51
#805488
1981 Kz550D1 (Gpz) uses 36mm forks.
Strange but true, the later 1982-83 Kz550H1-H2 (Gpz) uses 35mm. The OD is smaller, but the walls are thicker.
The following user(s) said Thank You: Mikey_V
  • martin_csr
  • martin_csr's Avatar
11 Jun 2019 05:06 - 11 Jun 2019 06:04
#805496
Fork tube chart link for future reference. The 550-D1 isn't listed in the pdf, but from the cross-reference at Partzilla
the 81 GPz 550 has the same fork seals as the 550A/C models. same seals = same diameter.
Ohio Cafe Racers Fork Tube Size Chart pdf
Partzilla >> 1981 KZ550-D1 >> Front Forks
Last edit: 11 Jun 2019 06:04 by martin_csr.
  • Mikey_V
11 Jun 2019 07:19
#805508
thanks guys!
  • loudhvx
  • loudhvx's Avatar
11 Jun 2019 09:12
#805516
Like Martin said, the 81 Gpz has same 36mm fork diameter as the Kz550A (standard) and Kz550C (chain-drive Ltd) models.
