Cast Wheel indentification help
  • Girvin71
  • Girvin71's Avatar Topic Author
03 Jun 2019 14:04
#805083
Hi guys, looking for help with this rear wheel. I have Henry Abe wheels for my Z1 and H2 but this set has a Henry Abe front and this rear which I have included pics. It has no casting info other than Japan and a date stamp. Seven star like Henry Abe but the machined surfaces of the stars dont go all the way to the outer rim surface like the Abe and also its has a 4 bolt carrier so maybe its a small bore Honda fitment. They are not Shelby Dowd. Any help would be greatly appreciated as this has bothered me for years not knowing. Thanks
Attachment not found
  • Girvin71
Re: Cast Wheel indentification help
03 Jun 2019 14:07 - 03 Jun 2019 14:17
#805084
Pics attached
Last edit: 03 Jun 2019 14:17 by Girvin71.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
03 Jun 2019 17:41
#805107
The only wheel info i found for you...
z1ownersclub.co.uk/phpBB3/viewtopic.php?...it=Henry+Abe#p374390
Henry Abe star mags
  • Girvin71
03 Jun 2019 18:21
#805115
Thanks for that but I have 2 sets of Abes already and this rear is different than them. They have H.A. Industries Cast into them and the machined surface extends further at the point of each triangle. Appreciate the help.
03 Jun 2019 18:52 - 03 Jun 2019 18:54
#805117
Like Scirocco I believe you will find they are Henry Abe wheels even if they are a bit different than the other ones you own. Ed
Last edit: 03 Jun 2019 18:54 by 650ed.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
03 Jun 2019 19:01 - 03 Jun 2019 19:02
#805119
Maybe i Need some new googles, can you point me to the difference in the casting.
Last edit: 03 Jun 2019 19:02 by Scirocco.
  • Girvin71
03 Jun 2019 21:15
#805126
No I cant because I only looked at front wheels for reference. I was wrong, you are absolutely correct then. Any idea of the application which initially was my first concern until I mistakenly 2nd goes myself believing the rear wasnt an Abe. I was initially told RD400 or Honda. Thanks again!
