Phenolic brake piston surface repair?
  • runmikeyrun
  • runmikeyrun's Avatar Topic Author
19 May 2019 13:46
#804188
Hi everyone.
One of the phenolic pads on my metal brake piston is chipped away. I was wondering if I can sand it down flat and still use the piston or if I HAVE to replace.
I say have to because I know we should t skimp on stuff like brakes. However, a new piston is $60 and I just don’t have the cash right now. If it’s safe enough to use on the rear by sanding it flat then that’s what I will do. My impression is the phenolic has to do with resisting heat transfer. If it’s on the rear it should get way less heat than the fronts.
Thoughts?
Monkey? MONKEY? I'm a GORILLA you CLOWN!
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Phenolic brake piston surface repair?
19 May 2019 15:11
#804190
What the hell are phenolic pads, any pics???
  • runmikeyrun
19 May 2019 15:51
#804193
Maybe I wasn’t clear, the end of the piston has a wafer of phenolic material on it. The brake pads themselves are not.
It’s the brown part on top of the piston.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
19 May 2019 16:13
#804194
Ahh, remember seen this on a ZX900/1000 caliper, your wafer are an anti squeak pad.
No Need to to use them anymore with a light layer of copper grease on the backside of the brake pad
  • runmikeyrun
19 May 2019 18:03
#804203
Awesome, thanks!! I appreciate it.
