Front brake caliper z500 b3 question
  • Swedez500
  • Swedez500's Avatar Topic Author
12 May 2019 13:48
#803726
Hi there Folks,
Attached picture shows the two shafts on the brake pads caseholder for my z500 -81. One of the shafts (marked) seems to be stiff while the other runs smoothly... same on both sides right/left. Supposed to be like that?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Front brake caliper z500 b3 question
12 May 2019 14:14
#803727
Remove the shafts (all) from the rubber boots give them a good clean and grease.
The following user(s) said Thank You: Nessism, Swedez500
  • Oldjeep
  • Oldjeep's Avatar
12 May 2019 16:14
#803736
One pin on each side has a rubber sleeve on the pin. Mine were stuck and a pain to remove from the pad carrier.
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
The following user(s) said Thank You: Swedez500
  • loudhvx
  • loudhvx's Avatar
12 May 2019 18:33
#803746
Yes, one slide should have some resistance while the other runs smooth. The resistance one has a rubber sleeve on the shaft like Oldjeep said. Many cars are like that too.
It helps against squeal.
  • Nessism
  • Nessism's Avatar
12 May 2019 19:15
#803750
Heavy black moly caliper grease works well for that application.
  • Swedez500
12 May 2019 23:14 - 13 May 2019 02:15
#803765
Loudhvx:
Ok. Some resistance you say. Mine seems quite stuck?
Last edit: 13 May 2019 02:15 by Swedez500.
  • Swedez500
12 May 2019 23:16 - 13 May 2019 02:17
#803766
Oldjeep:
How did you manage?
Last edit: 13 May 2019 02:17 by Swedez500.
  • Oldjeep
  • Oldjeep's Avatar
13 May 2019 03:31 - 13 May 2019 05:50
#803770
Swedez500 wrote: Oldjeep:
How did you manage?
i sprayed pentrating oil around the pins and did a lot of twisting and pulling to get them out. Do not apply heat. I was surprised how difficult they were to remove. But once cleaned up and regreased with high temp caliper grease they move quite well.
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
Last edit: 13 May 2019 05:50 by Oldjeep.
  • loudhvx
  • loudhvx's Avatar
13 May 2019 07:46 - 13 May 2019 08:12
#803783
Maybe someone used the wrong type of lubricant and maybe it had a chemical reaction with the rubber, if it is indeed the rubber that is stuck and not rust. Sometimes it causes the rubber to expand.
The manual calls for PBC Poly Butyl Cuprysil grease on the holder shafts and the "friction boot", which is that rubber sleeve.
Last edit: 13 May 2019 08:12 by loudhvx.
  • Nessism
  • Nessism's Avatar
13 May 2019 08:57 - 13 May 2019 10:24
#803788
loudhvx wrote: Maybe someone used the wrong type of lubricant and maybe it had a chemical reaction with the rubber, if it is indeed the rubber that is stuck and not rust. Sometimes it causes the rubber to expand.
Good point. Suzuki GS bikes had the same problem; there was a plastic sleeve around one of the pins that would swell and keep the caliper from sliding properly. I've been using Permatex Silicone Disc Caliper grease without issue but using proper PCB grease might be safer. Nissan sells PCB grease specifically designed for brake parts but it's expensive. If anyone knows of a cheaper alternative please share. www.amazon.com/gp/product/B00BNVJQDC/ref...=ATVPDKIKX0DER&psc=1
Last edit: 13 May 2019 10:24 by Nessism.
The following user(s) said Thank You: loudhvx, Swedez500
  • Oldjeep
  • Oldjeep's Avatar
13 May 2019 09:37
#803793
I used this stuff, costs $1.50 a packet - never thought to look at a manual for pin grease ;)
VersaChem Synthetic Synthetic Caliper Grease
www.itwconsumer.com/versachem-products/p...ease%2C%20packet-100
Chuck
81 KZ750 LTD
03 FZ1
www.oldjeep.com
  • loudhvx
  • loudhvx's Avatar
13 May 2019 10:16 - 13 May 2019 10:24
#803800
Nessism wrote: ...Nissan sells PCB grease specifically designed for brake parts but it's expensive. If anyone knows of a cheaper alternative please share. www.amazon.com/gp/product/B00BNVJQDC/ref...=ATVPDKIKX0DER&psc=1
Thanks for the heads up on the Nissan grease. I can use that for the car and KZ... i might look for a smaller package.
I've been using Sil Glyde (Silicone based grease, I think) for decades as it claims to be for this exact application and won't harm rubber. So far it has worked very well but I'd rather use the right stuff. I've googled to see if Sil Glyde is cross compatible with PBC but not any definitive answer yet.
Last edit: 13 May 2019 10:24 by loudhvx.
