KZ750 18in front tire swap
  • ZeffRides
  • ZeffRides's Avatar Topic Author
10 Apr 2019 16:15
#801940
Does anyone know of an easy swap in 18" front wheel to replace the stock 19" on a 1976 kz750 twin?
1976 KZ750B1
1978 CB750K
2002 BMW 530i 5-speed
  • ZeffRides
Re: KZ750 18in front tire swap
10 Apr 2019 16:19
#801941
Perhaps a kz400 18" front rim laced up to the 750 hub using kz400 spokes?
1976 KZ750B1
1978 CB750K
  • z1kzonly
  • z1kzonly's Avatar
10 Apr 2019 17:00
#801943
Yes, Later KZ400 - 78 is identical. even has the 4 holes on opposite side for a dual disc.
  • Nebr_Rex
  • Nebr_Rex's Avatar
10 Apr 2019 17:22
#801945
The KZ400 hubs I have seen look the same as the KZ650 and up hubs but are lighter duty.
There is less mass in the center. Also check the diameter of the spokes KZ400 vs. the KZ750B.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
10 Apr 2019 18:04
#801946
A KZ400 weighs a bit less than 400 lbs. A KZ750 twin weighs about 500 lbs. Before swapping I would make sure the smaller wheel would be able to handle the weight difference without any problem. Ed
