Kz650 B1 dual conversion confirming
- perper
10 Mar 2019 08:54
Hi everyone. I've been studing the forum un order to convert to dual disk my kz650 B1 and, if i understand, one way that goes nice is first twist the bottles (i can do it without problema, is It?) and buy a pair of gpz750 83-85 calipers. These calipers will fit bolt-on, without other invents?
And, of course, change the MC to a 16 mm.
What about the rotor? Can i install on the other side other rotor of kz650 B1? Or its better change both?
Thanks and sorry if this subjet was very written, i sure you i've been reading a lot!
Thanks
Thanks
Kz400 D3 1976
Kz650 B1 1977
Kz650 B1 1977
Re: Kz650 B1 dual conversion confirming
10 Mar 2019 14:07
Keep in mind if you turn the bottom fork legs around the tabs for connecting the fender brackets will be facing forward instead of toward the rear. Ed
The following user(s) said Thank You: perper
- bluej58
10 Mar 2019 14:25 - 10 Mar 2019 14:33
When I changed to dual discs I found a set of calipers off an LTD and got the 2 discs and splitter in the deal.
A dual disc setup has thinner discs than a single disc setup and there may be a difference in the calipers too.
Make sure you get a 5/8 master cylinder, the stock one for a single disc will not work right for a dual disc setup and can be dangerous.
78 KZ1000 A2A
Last edit: 10 Mar 2019 14:33 by bluej58.
- perper
11 Mar 2019 07:55
Ok, thanks! I will post the news about my conversion.
Kz400 D3 1976
Kz650 B1 1977
Kz650 B1 1977
11 Mar 2019 08:22 - 11 Mar 2019 08:23
I used two H2 calipers and stock KZ 900 disks on mine. The brakes worked fine on mine but I went with a larger GPZ master cylinder later. The stock disks are thick so thinking of unsprung weight I went with the later style stock drilled disks that are about half the weight. The disks are thinner but the holes caused a pulsing at the lever. I changed the brake pucks from organic to sintered and the pulsing went away. I'm happy with my setup and I have my solid disks as spares.
BTW, I turned the legs around and used two left hand calipers. I had to use a washer to shim one bolt on the left side and the bleeder valve is pointing down. I have to bleed that one at the banjo bolt and I can pick up a bracket for the left side at z1partsinc.net if I need to. They also have a caliper that will work for the left side but at this point there other things I'd rather spend money for the bike on.
Not sure about the 650's though but it seems parts for them are cheaper used than for the bigger fours.
Last edit: 11 Mar 2019 08:23 by SWest.
- 9er rider
- Keep a cool tool
11 Mar 2019 11:22
I've done this a few times kz900 and a 1000 and starting another on the way, and s/s braided brake hoses with nice front hose brackets are a must have. I poor boyed the thousand with aftermarket rubber and seemed squeezy compared to the S/S set up, I like rock hard controls two finger style.
- DOHC
- Those Doe-Hawks really go!
11 Mar 2019 19:36perper wrote: Hi everyone. I've been studing the forum un order to convert to dual disk my kz650 B1
Here are a few things to know about the KZ650 front brakes.
1) For KZ650 models that came with two front disks, the double disks are both thinner than the single disk, and they are also smaller diameter.
2) Forks on the two disk models have the caliper mounting holes located closer to the axle. The caliper brackets are the same for both models. Kawasaki changes the forks, not the calipers.
3) The smaller and thinner disks have the same bolt pattern and offset as the single disk. The 2-disk setup will bolt onto the KZ650B spoke wheel hub and work fine.
I had a 1979 Kz650B3. I bought a set of disks from a 2-disk model (Kz650C or D) and discovered that the disks were smaller diameter, so the calipers were not in the proper location. I then bought a set of forks from a 2-disk bike, and swapped the forks as well. The 2-disk setup worked great.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
12 Mar 2019 06:47
Some more info.....
The KZ650B and E models had front rotors with a swept area of 250mm and a thickness of 6.9-7.1mm. The KZ650C, D, and F models had front rotors with a swept area of 231mm and a thickness of 4.9-5.1mm. Ed
- perper
16 Apr 2025 13:53
Hello! Years later, i have got two gpz calipers and two kz1000 rotors. And 16 mm mc. Im waiting my postman with these things vert nervous. I Will post the resulta.
My new question is about the diferent options in the brake lines, which option do you think is better?
1- Two brake lines from the MC with a doble banjo bolt, one line to one caliper, one line to the other caliper.
2- Getting a kz650 double rotor splitter.
3- Look for an aftermarket "T" (splitter).
Thanks!!!!
Thanks!!!!
Kz400 D3 1976
Kz650 B1 1977
Kz650 B1 1977
- StreetfighterKz
16 Apr 2025 14:03
What master cylinder do you plan on using? The stock Kz650 has the brake pressure switch at the junction on the lower triple. Going with two lines will eliminate that and you’ll have to find another way to activate the brake light. Long ago on my Kz1000, I simply used the stock single outlet junction with a double banjo bolt for two lines to the calipers.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- perper
17 Apr 2025 06:35
Thank you, Doug. Im using a new brembo 16 mm MC with his own brake sensor on it, I dont need the splitter with pressure for the light brake. I think your option is the best in order to have less places who can leak, isnt?
Thanks for the response and sorry for mu english!
Greetings, Perper.
Greetings, Perper.
Kz400 D3 1976
Kz650 B1 1977
Kz650 B1 1977
- perper
30 Apr 2025 12:25
Im on the way!!
[attacment=177037]PXL_20250430_181657652.jpg[/attachment]
I think the calipers will fit bolt-on, from a gpz750 1983-1985 ZX10A, with the rotors from a kz1000, drilled, 4,5 mm.
One thing i'm sure will not fit is these calipers with the origin rotor (7 mm), the brake caliper has some small tabs to hold the pad that prevent a wider rotor from fitting.
Step by step, the kz will brake well. I hope to have more news soon, the kids don't let me work much on the motorbike!!!
Kz400 D3 1976
Kz650 B1 1977
Kz650 B1 1977
