Front wheel change out.
- Flyingsince57
07 Mar 2019 16:21
No eBay APP ID and/or Cert ID defined in Kunena configurationHello, I have a 76 KZ750 twin with a Lester back mag and a spoke front end. I want a Lester for the front but they are as rare as a hens tooth. I would put on a Kaw mag if I knew it would fit. On ebay there is a 76 that they claim came off a 750 twin. I did not know that they made them with factory mags back then. Does anyone know if this is true and if it is so, does it just change out with the laced wheel? Any info is greatly appreciated, Here is the ebay link for the wheel and a picture of my bike if it will load. Please do not buy it out from under me:)
- WarrensKZ
Last edit: 07 Mar 2019 17:03 by WarrensKZ.
Re: Front wheel change out.
07 Mar 2019 17:32 - 07 Mar 2019 17:33
The 1976 KZ750-B came with wire wheels, so whoever is selling it is confused (at best). However, the 1980 KZ750-G1 (LTD II twin) and possibly some other year/model KZ750 twin did come with cast wheels (see link below). The question is whether or not the wheel in the eBay listing is really from a KZ750 twin since the seller posted inaccurate info regarding the year and model of the donor bike. Ed
www.google.com/search?biw=1366&bih=616&t...imgrc=zWCR9ryTl1F2VM :
Last edit: 07 Mar 2019 17:33 by 650ed.
The following user(s) said Thank You: Flyingsince57
08 Mar 2019 07:27 - 08 Mar 2019 12:06
Someone could have installed cast alloy wheels before the seller got the bike.
Are you wanting a single disk or dual disk? The EB wheel appears to be dual disk.
I would figure out what wheels can be used on the 750B, then see what's available.
Last edit: 08 Mar 2019 12:06 by martin_csr.
- kawiwowi
08 Mar 2019 07:57
I replaced the stock wheels on my 1976 KZ750 with the cast wheels off of a KZ750 H 4 cylinder. I also swapped the forks and front brakes. Pretty simple swap.
08 Mar 2019 08:35
Did you just swap the forks or the triple tree as well?
08 Mar 2019 09:10
I think the '76 KZ 900 came with KHI mag wheels.
- Dr. Gamma
08 Mar 2019 10:29 - 08 Mar 2019 10:30hardrockminer wrote: I think the '76 KZ 900 came with KHI mag wheels.
1976 KZ900A came with spoke rims.
1976 KZ900B1 (LTD) came with real Morris cast rims.
The 1977 KZ1000B1 (LTD) was the first 1000cc bike with Kawasaki factory cast rims
The cast rim pictured in first post looks like a 1980 and up KZ750/4 front to me.
1986 RG500G 2 stroke terror.
Last edit: 08 Mar 2019 10:30 by Dr. Gamma.
- kawiwowi
08 Mar 2019 19:13
To the best of my memory, I kept the original triple tree. But it was appox. 15 years ago, and I can't say with 100% certainly. Also, I used the wheels off of a KZ750 E model (19" & 18"), not the H. The forks are from a H model.
09 Mar 2019 05:41 - 09 Mar 2019 06:38
Thanks. I think the 750H Ltd Fr wheel is the same as the 750E. and some other 750-4 models as well.
Last edit: 09 Mar 2019 06:38 by martin_csr.
