KZ400 and 650 steering stem removal
  • QCkaw
  • QCkaw's Avatar Topic Author
  • 1978 KZ650-B2
06 Feb 2019 09:47 - 06 Feb 2019 10:35
#798280
Hello all,
I am swapping the front end on my barn find '74 KZ400 with the entire stock front-end left over from my previous '78 KZ650 restomod... The stems are the same wrt bearing sizes, however the 650 stem is about 1" longer. I need to swap the 650 stem with that from the 400.
After I grind away the weld, can anyone answer for me which way the 400 stem presses out of the lower triple clamp?
Same question for the 650?
Thanks!
Last edit: 06 Feb 2019 10:35 by QCkaw.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: KZ400 and 650 steering stem removal
06 Feb 2019 14:51
#798296
Press out the stem from the bottom.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
